Kia Sportage Recall #811624 05/12/07 04:53 PM
hvac1000 Offline OP
Make : KIA Model : SPORTAGE Year : 2002
Manufacturer : KIA MOTORS AMERICA, INC.
NHTSA CAMPAIGN ID Number : 07V161000 Mfr's Report Date : APR 13, 2007
Component: ENGINE AND ENGINE COOLING:COOLING SYSTEM:FAN
Potential Number Of Units Affected : 35090
Summary:
ON CERTAIN VEHICLES, THE HEAT GENERATED BY THE ENGINE CAUSES REPEATED BENDING DEFORMATION OF THE POLYPROPYLENE COOLING FAN INCLUDING ITS RETAINING RING, WHICH STRESSES THE POLYPROPYLENE THEREBY INITIATING CRACKING OF THE BLADES. THE CENTRIFUGAL FORCES GENERATED BY THE ROTATION OF THE BLADES CAN CAUSE THE CRACKS TO PROPAGATE UNTIL COMPLETE SEPARATION OCCURS.
Consequence:
SEPARATION OF THE FAN BLADE(S) CAN CREATE A RISK OF PERSONAL INJURY.
Remedy:
DEALERS WILL REPLACE THE ENGINE COOLING FAN WITH A FAN MADE OF IMPROVED MATERIAL. THE RECALL IS EXPECTED TO BEGIN DURING JUNE 2007. OWNERS MAY CONTACT KIA AT 1-800-333-4542.
Notes:
KIA RECALL NO. SC070. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Re: Kia Sportage Recall [Re: hvac1000] #811625 05/12/07 08:18 PM
DEFBOY35 Offline
this is only for 2002? because this sounds exactly like what just happened to my fan that sent 2 blades rite through my rad!!!
I will have to go down to the stealership and see what can be done!
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: Kia Sportage Recall [Re: DEFBOY35] #811626 05/13/07 09:34 AM
Axe Man Offline
Kia Moderator Emeritus
Interesting. I did some checking on the kiausaparts site. That fan has changed part number quite a few times over the years.
For example:
1995 - 0K011 15140
1998 - 0K028 15140
2001 - 0K01W 15140
2002 - 0K01W 15140 until 6/21/01
2002 - 0K048 15140A after 6/21/01
I have no clue as to what the changes were.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Kia Sportage Recall [Re: Axe Man] #811627 05/13/07 10:57 AM
P
porky Offline
mine broke the blades at 60 thousand kms 7 months out of new car warrenty it took out the radiator + fan gaurd + air conditor pipes and the power steering pipes
i spoke to the local kia dealer and he said there was nothing they could do about it as it out of warrenty it cost me just over 1500 aust dollars to fix and they told me they put a updated fan and clutch as kia had updated the parts
but now when the 8 bladed fan kicks in at about 3 thousand revs it lets out a loud roaring sound then fades away as it cools down
the mechnic said at least you can hear it working
wish i had have gone to a electric fan like everybody else on here has
Re: Kia Sportage Recall [Re: hvac1000] #811628 05/14/07 01:14 AM
Hydra747 Offline
Good Information!
Where did u get your source?????
Cause according to AXEMAN the 01's used the same part as the 02's????? <img src="/forums/images/graemlins/confused.gif" alt="" />
Are they specific with only the 02's?
I have read the problem with the fans breaking off and causing destruction about a year ago when I first joined! <img src="/forums/images/graemlins/confused.gif" alt="" />
Why is it displayed as only the 02's in year?
Re: Kia Sportage Recall [Re: Hydra747] #811629 05/14/07 02:40 AM
Axe Man Offline
Good Information!
http://www.kiausaparts.com
Re: Kia Sportage Recall [Re: Axe Man] #811630 05/14/07 03:02 AM
kiarazy Offline
mine gernaded a year ago and i replaced it with oem from the stealer i wonder if the replacement is bad too
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
Re: Kia Sportage Recall [Re: kiarazy] #811631 07/26/07 08:27 PM
Superzuk Offline
That's what happened to the truck I just picked up.... replacing the engine this weekend.... I was hoping it was just a timing belt.... <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Kia Sportage Recall [Re: hvac1000] #811632 07/26/07 10:48 PM
Yankee_Tim Offline
Mine is a 2002. <img src="/forums/images/graemlins/smile.gif" alt="" /> Shannon already has it scheduled to be done first as soon as the new parts come in.
Yankee Tim
Re: Kia Sportage Recall [Re: Yankee_Tim] #811633 07/27/07 01:33 AM
Calappoyas Offline
Did mine last week. took them 20 minutes.
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils
http://www.cardomain.com/id/calapooyas
My beater, 03 Land Rover Freelander SE3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6403 MB (Peak: 0.7655 MB) Data Comp: Off Server Time: 2026-05-29 19:54:45 UTC
