rear end #811643 05/12/07 07:47 PM
kc85 Offline OP
I'm installing third members with 5.29 aussie lockers,put the rear in with no gasket just silicone and rotate yoke about 3 times stops like its hitting something(no axles).pulled it back out and can't see where anything hit anything.any ideas?does it need gasket for clearance issues?local shop setup gears they look good.pulled fill plug while it was in,was not it.
Re: rear end [Re: kc85] #811644 05/12/07 08:54 PM
4Crawler Offline
I usually run just silicone and have no issues like that. Does the 3rd bind up like that with it out and with it in place but not bolted down tight?
Re: rear end [Re: 4Crawler] #811645 05/12/07 09:55 PM
kc85 Offline OP
sorry didn't answer back sooner was working on it.don't know what it was,didn't do it out of truck,put it back together and it worked fine, already drove it,works good.thanks you guys are always helpful,learn alot from this site.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5948 MB (Peak: 0.6479 MB) Data Comp: Off Server Time: 2026-06-22 11:21:30 UTC
