Page 3 of 4 1 2 3 4
Re: Lift kits [Re: Iron] #811713 05/15/07 09:45 PM
Lennyburger Offline
With a strong tail wind! smile <img src="/forums/images/graemlins/evil.gif" alt="" />
With all the hype about greenhouse gases and the like, maybe a sail-driven KIA might be a good idea???? With a lift kit you could get higher than other cars and reap the benefits of high altitude wind gusts <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
KIA, More dirt for ya dollar! 99 Sportage, Pod filter, Bosch Super4 plugs, electric thermo fan, racing pedals, Narva 100W driving lights, Yokhama 235/75R15 Super Diggers....getting to the rest bit by bit.
Re: Lift kits [Re: Iron] #811714 05/16/07 01:29 AM
DEFBOY35 Offline
haha, i am sure i still am able to hit around 115 on the highway with the 31's
well, i didnt say without!! and i didnt say whether i was going down a hill or not either!!! <img src="/forums/images/graemlins/drunk.gif" alt="" />
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: Lift kits [Re: MemphisFred] #811715 05/19/07 02:10 AM
LeadBelly Offline
...locked and loaded Samurais, they had 1.3L, 205/70R15 tires with 3.73 gears stock. The available gear ratios were 4.57, 4.88 and 5.12...
Samurai transfer cases are not direct (1:1) in high range like the KIA (and just about every other 4x4) High range has a 1.409:1 reduction. (low range is 2.268:1) So camparing final drive ratios and their effects on perceived power between a Sportage and a Sammy is kinda an apples/oranges thing. Just my .02.
'99 Sportage 4dr EX 5-speed, unmolested
'98 Sportage 4dr Auto 2wd
'96 Sportage 4dr Auto,235-75x29"tires, custom fabbed hidden receiver hitch and big plans.
Re: Lift kits [Re: LeadBelly] #811716 05/23/07 08:47 PM
MemphisFred Offline OP
Sorry, was on vacation last week when you posted this. I agree that the ratio is different but I wouldn't say apples to oranges. Here are the stats figureing the KIA with 5sp.
I did the figures with A/T and they really sucked. Crawl ratio with the A/T (which is what I have), is 26.760.
Samurai.....Kia
1.409........1.0 Transfer low
3.652........3.717 1st Gear (already lower)
3.73..........4.78 Diff gear (already lower)
30.895......35.197 Crawl ratio
So the Kia 5spd vs. Samurai with same size tires already has a lower crawl ratio than the Samurai and add in the fact that it has a bigger engine and fuel injection against the Sami carburetor.
So, nobodys making gear sets but I'm wondering if we could possibly get some different gears for the T-case. Did any earlier models come with high diff gears, if so maybe their T-case would have different gearing to compensate, that could be swapped into ours.
No matter where you go, there you are!
"Buckaroo Banzai"
Re: Lift kits [Re: MemphisFred] #811717 05/24/07 12:29 AM
DEFBOY35 Offline
there is none available from any year as far as i know. i am sure if they were available many of us would have them!
and for your calculations, the transfer case low is actually 1.98:1 gearing not 1.0 for the sportage. and from what i have been told, the sami's 1.4.... is the high reduction, and it is reduced even further when in low!
Re: Lift kits [Re: MemphisFred] #811718 05/24/07 03:23 AM
kiarazy Offline
On the subject of gears and lockers, I've read on here that the ratios are 4.78. That's actually pretty low already.
Digressing to my days running locked and loaded Samurais, they had 1.3L, 205/70R15 tires with 3.73 gears stock. The available gear ratios were 4.57, 4.88 and 5.12. Now, the 4.57 would bring the Samurai running 33's back to street tolerances while the 4.88 and 5.12 would of course give you more crawling capabilites.
Now, the Sami's only weighed 1836 lbs compared to KIA at 3500 lbs. (Damn that's heavy for such a small vehicle). That means the KIA already has a bigger motor and lower gears with the same size tires, so does the weight have that much to do with it or does the transmission and transfer have that high of gears?
Anybody have one lifted with bigger tires that is an A/T? How does the A/T do pulling those bigger tires?
i would agree but also disagree i have 31s and a five speed and i spend a hour of my day driving 75 mph plus and it does just fine i am sure i could run 35 inch tires in it would be in your so called street tolerance. i also know that a stock samuri has a hard time doin 75 mph. so yes i think the kia is geared lower and does have more power, but i think you just have to define "street tolerances" better because if i slap 35 inch tires on there is no way i will be able to do highway speeds but if i am just running down the road to the local watering hole no prob. <img src="/forums/images/graemlins/cheers.gif" alt="" />
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
Re: Lift kits [Re: DEFBOY35] #811719 05/24/07 03:27 AM
kiarazy Offline
i hit it all day just no wind or tail wind if i have head wind i just keep it out of 5th gear i am also running it at about 4200 rpm in fourth when i am going that fast
Re: Lift kits [Re: kiarazy] #811720 05/24/07 04:00 AM
Oh of course, I agree. Larger tires will always put some strain on all parts of the drive train from eng, tranny, t-case, drive shafts, axles, you name it. You always have to bring it back into line with either diff gear or t-case reduction or both. You can run any size tire with the right gearing.
"Buckaroo Banzai"
Re: Lift kits [Re: MemphisFred] #811721 05/25/07 01:05 AM
Cen_Tex_KIA Offline
Could be worse, I have friend with a 2005 jeep wrangler, it has to shift outta od to go up a overpass on the freeway withe a/c off! Now it has 31's and it's even sadder!
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
Re: Lift kits [Re: Cen_Tex_KIA] #811722 05/25/07 07:44 PM
Cen-Tex-KIA, was through your town last week on vacation. Man, the traffic is heavy on 35e. Was like rush hour traffic all hours of the day.
"Buckaroo Banzai"
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6464 MB (Peak: 0.7699 MB) Data Comp: Off Server Time: 2026-10-21 19:13:27 UTC
