Installing a larger rear seat in a YJ? #811758 05/13/07 06:49 AM
darkroom1428 Offline OP
Has this been done? I'm wanting to make my 93 YJ a 5 seater and I was planing on cutting the wheel walls and making them smaller to put a longer seat in the rear. With my lift and aftermarket rims i've been able to clear some room in the wheel wall so i was waning to see if anybody had pics or any idea how to make it possible
Thanks
lee
Re: Installing a larger rear seat in a YJ? [Re: darkroom1428] #811759 05/24/07 07:52 PM
3
3535 Offline
Ribicon express has a back seat that they sell for TJ's its much wider and has 3 belts in it.
Re: Installing a larger rear seat in a YJ? [Re: darkroom1428] #811760 05/24/07 10:13 PM
F
Fred Blackstone Offline
It probably has been done before, very little that hasn't been done to the old YJ's! I would recommend not cutting into the wheel wells: instead, "engineer" a seat anchoring riser to provide clearance above the sloping wheel wells to fit a larger rear seat from another type vehicle. I was just wondering if you're planning to use the YJ to haul tourist about the Canyon? I've only seen pictures of the Canyon Dechelly, it appears to be a great destination to learn more about our Country's pre-1500's inhabitants in the southwest?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5951 MB (Peak: 0.6477 MB) Data Comp: Off Server Time: 2026-05-29 17:26:39 UTC
