AC Compressor out 85 4Runner? #811845 05/14/07 03:58 AM
jaredl Offline OP
Hello all, I am new on this forum and am hoping for some help. I have an 85 4Runner that I believe the compressor is out on. The AC light comes on, but the compressor does not kick in. I checked for fuses, but could not find one for the AC. The compressor manually turn if I turn it. It worked last Summer. Any thoughts?
Thanks,
JARED
Re: AC Compressor out 85 4Runner? [Re: jaredl] #811846 05/14/07 04:06 AM
toyrunner Offline
Thanks,
JARED
low on refrigerant. have it serviced(checked/recharged)
Danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: AC Compressor out 85 4Runner? [Re: jaredl] #811847 05/14/07 04:10 AM
kewlynx Offline
Your fuse is fine; getting power to the AC switch; also check for voltage at the compressor plug. Fuse, if ever needed, is next to the one for the heater, behind the glovebox, right side of console.
x2 on getting it serviced.
**ubi apis- ibi salus**
Re: AC Compressor out 85 4Runner? [Re: toyrunner] #811848 05/14/07 04:20 AM
cktoy Offline
I think it sounds like a low charge too,you can jump out the low pres switch and tell for sure,the 134a conversion kit at autozone does pretty good for the money,but you need a vacume pump too do it right
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: AC Compressor out 85 4Runner? [Re: jaredl] #811849 05/14/07 04:22 AM
4Crawler Offline
The compressor should be cycled on periodically to keep everything lubricated inside. Leaving it off all winter can lead to seals frying out and leaking. But it could be as simple as the A/C amplifier RPM setting being set too high. If you are trying A/C at idle and it does not come on, but does if you rev the engine, turn the RPM adjustment knob down (behind the glove box).
Re: AC Compressor out 85 4Runner? [Re: jaredl] #811850 05/14/07 06:39 AM
Davepet Offline
Do you mean the ac clutch doesn't engage, or that you just don't get cold air? If the clutch engages, the electrical side of things is fine, if not check for voltage at the clutch & work from there.
If it does engage then it's time for refrigerant.
Dave
Thanks all [Re: jaredl] #811851 05/16/07 04:09 AM
jaredl Offline OP
Thanks all. I will try the fuse first and go from there.
JARED
Re: Thanks all [Re: jaredl] #811852 05/25/07 05:24 AM
jaredl Offline OP
Update!
Still can't find the %^&$# fuse. I think everyone is right in assuming I need to get it serviced. Thanks,
JARED
Re: Thanks all [Re: jaredl] #811853 05/25/07 06:33 AM
kewlynx Offline
Okeedokey, for your peace of mind for THAT fuseblock.
Empty junk out of glovebox.
Take a small screwdriver and gently pry the closeout curtain off the dash (note the little triangles in the trim).
Unscrew the glovebox hinges; remove glovebox.
AC, Heater fuses, and heater relay are present, along with the plug for the fan switch.
Service that puppy up and let us know how ya do.
Re: Thanks all [Re: jaredl] #811854 05/25/07 07:23 AM
Davepet Offline
jaredl,
Did you check to see if the compressor clutch is engaging? That is far easier than getting to that fuse....
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6348 MB (Peak: 0.7421 MB) Data Comp: Off Server Time: 2026-10-24 08:18:13 UTC
