Just when I thought I was done #812006 05/14/07 11:51 PM
F
ffountain Offline OP
My 86 22RE 4Runner does'nt want to start in the morning or afternoon after it has been sitting for 4 or 5 hours. When it does start (after several minutes(3 or 4) of turning the starter on and off) it acts like it is skipping until I give it a little throttle. After it starts and I drive out of the parking space, it seems to run fine. But the next day I have the same problem. I don't want to wear out the starter, so I need a list of things to start looking at.
Re: Just when I thought I was done [Re: ffountain] #812007 05/15/07 01:00 AM
Elbow_Greese Offline
Is the starter actally cranking the engine or does it just "click"?
This will help narrow it down.
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: Just when I thought I was done [Re: Elbow_Greese] #812008 05/15/07 04:41 AM
4Crawler Offline
If the starter is turning the engine over but it is not starting, try the fuel pump test jumper:
http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
Forces the fuel pump on.
Re: Just when I thought I was done [Re: 4Crawler] #812009 05/15/07 12:02 PM
F
I placed a jumper in the test connector when it first began to give me a problem. The fuel filter has also been replaced. I seem to be getting fuel to the engine. Once the engine runs it will start with no problem. But after 3 or 4 hours same problem.
Re: Just when I thought I was done [Re: ffountain] #812010 05/15/07 04:03 PM
4Crawler Offline
You need fuel, air and spark to run the engine. See if you can determine which one(s) is missing when you have the starting problem. Could be one of the cold start components (CS injector, the CSI time switch, ECU temp sender) for example, not kicking in the cold start system.
Re: Just when I thought I was done [Re: 4Crawler] #812011 05/28/07 03:43 PM
F
When I checked the resistance on the CSI time switch I got none. Does anyone know where I can get a used one? The local parts stores sell new for around $140-160. I plan to sell this 4Runner and the more I spend the less I get in return.
Re: Just when I thought I was done [Re: ffountain] #812012 05/28/07 07:48 PM
4Crawler Offline
Re: Just when I thought I was done [Re: 4Crawler] #812013 06/03/07 02:58 PM
F
Is there no way to bypass the CSI time switch to make sure the CS injector is also working?
Re: Just when I thought I was done [Re: ffountain] #812014 06/03/07 09:01 PM
Frank Torres Offline
Yes...
For years (due to a bad ecu) I HAD the CSI wire directly to the battery through a toggle switch on the dash. I would hit the switch for a second or two till it cranked and started. This is somewhat how the FSM shows how to test the the injector to apply 12 volts to one side and ground the other.
1991 FJ 80 Land Cruiser for fun.
1998 GS300 for the wife
1998 GS400 for me
1991 Supra SOLD
1986 4Runner 335k miles-22re EB inside.SOLD
Re: Just when I thought I was done [Re: Frank Torres] #812015 06/06/07 11:57 AM
F
Yes...
I will give it a try in the next few days. How did you determine that you had a bad ECU? I'm not getting a check engine light and I know the light works (kept lighting up until I replaced my O2 sensor). Also can the cold start injector be rebuilt/repaired? I remember reading about a place called RC engineering(I think) that rebuild injectors.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6448 MB (Peak: 0.7646 MB) Data Comp: Off Server Time: 2026-05-29 19:54:27 UTC
