alternator noise #812023 05/15/07 01:19 AM
N
nlexpcoa Offline OP
I have a 90 pickup 6cyl 4wd. I replaced the factory alt with the 160A high output alt that northwestoffroad.com sells. When I installed I had alt wine through my stereo. I dought a Ground loop isolator for my rca's and moved the power cable for my amp. Solved 95% of the problem. Now I installed a CB today and BAM, their it is again. What can I do?
I placed a noise filter on the power line for the amp, no good. A friend of mine says some cars have "condensors on their alt or dist. Did my old alt have one built in? can I add one to my new alt, and where? I have a 1/0 power cable that runs from the batt lug on the alt to the battery. can I just put one between the alt batt lug and the cable? are they one size fits all? Sorry for all the Q, I am lost. Pleae Help.
Nik
Re: alternator noise [Re: nlexpcoa] #812024 05/15/07 03:29 AM
4Crawler Offline
Run dedicated power AND ground wires from the battery, fused of course, twist the wires as they run back to the device. Add a noise filter near the device and connect to those power and ground wires. I run my wires down the passenger side, away from the ignition and alternator. No noise and I have a 160 amp PPW alternator.
Re: alternator noise [Re: nlexpcoa] #812025 05/15/07 03:41 AM
ScaldedDog Offline
I'm trying one of these next.
Mark
''Wise men talk because they have something to say; fools,
because they have to say something.'' - Plato
http://www.scaldeddog.com
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5971 MB (Peak: 0.6508 MB) Data Comp: Off Server Time: 2026-06-07 09:12:35 UTC
