Pulsing brakes #812206 05/16/07 04:09 AM
A
Ashokan1 Offline OP
Just did the front brakes on my '89 PU (with IFS) replacing the right rotor, both calipers and pads. In addition, I flushed the brake lines, both front and rear, with new fluid.
I am noticing a slight pulsing that is more evident at higher speeds but goes away with pedal pressure. If I just lightly apply the brakes I feel it but the harder I press the pedal, the less I sense it. No pulsing in the steering wheel or any other indicators of a problem. I didn't notice it prior to the brake job but I had a shot rotor/caliper so it may have been there before but unnoticed.
Any thoughts??
Re: Pulsing brakes [Re: Ashokan1] #812207 05/16/07 07:24 AM
rustylux Offline
Could just be the pads wearing in. Could also be that because you replaced one rotor and not the other the difference in thicknesses is a factor. Just throwing ideas out there.
Re: Pulsing brakes [Re: rustylux] #812208 05/16/07 10:01 AM
mqm Offline
Replace the left rotor also
Re: Pulsing brakes [Re: Ashokan1] #812209 05/16/07 05:20 PM
N
norcalsvx Offline
you should always replace both rotors at the same time
1994 toy 22re
Engbldr. street rv head 261c,LC header,Downey dualshocks, BJ spacers, OME torsions, 33x10.50 BFG muds budbuilt xmember/skid plate 4.88's locker custom exhaust
2006 Subaru Forester XT
1994 Subaru SVX
1979 Mazda rx7
Re: Pulsing brakes [Re: norcalsvx] #812210 05/16/07 09:25 PM
V
v8yota Offline
same thing happened to me,,,i used autozone rotors,,,autozone parts are junk,,,i changed the rotors and it was fine,,i could of gotten away with cutting the autozone rotors,,but why buy new rotors and get them cut
Re: Pulsing brakes [Re: v8yota] #812211 05/16/07 09:43 PM
IceBlueT Offline
did you torque the wheels to the right specifications? we sent my dads tundra to brakes plus <img src="/forums/images/graemlins/scared.gif" alt="" /> for a brake job. two new rotors, rebuilt the calipers, new pads, plus turned the drums and put new shoes on. a month after, my dad started feeling a pulsing sensation in the pedal. i pulled the wheels, balanced and rotated them, and torqued them to the correct 79 ft. lbs. no more pulsing.
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: Pulsing brakes [Re: IceBlueT] #812212 05/18/07 01:11 AM
A
Ashokan1 Offline OP
I admit I didn't torque the wheels. I did torque the wheel bearings with the preload and torqued it by hand afterward. I'll check it out more closely this weekend if the weather holds.
Thanks for the ideas.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6164 MB (Peak: 0.6901 MB) Data Comp: Off Server Time: 2026-06-23 01:19:39 UTC
