Temperature Gauge Sensor Location? #812504 05/17/07 12:19 PM
PitterCol Offline OP
On Monteros where is the ambient temperature gauge sensor located? It seems to me that almost anywhere on a hot car you would get a false reading.
Re: Temperature Gauge Sensor Location? [Re: PitterCol] #812505 05/18/07 04:10 AM
Out in front of the radiator somewhere. Any further back and it gets engine heat. You sometimes get a false high reading after a hot soak in still air, as the sensor picks up radiant heat from the radiator and engine, but air flow should get it back in sync pretty quick after you restart.
Re: Temperature Gauge Sensor Location? [Re: fasteddy] #812506 05/18/07 05:00 AM
justice Offline
If I remember right on the gen 2's its in the front bumper behind the plastic..
Re: Temperature Gauge Sensor Location? [Re: PitterCol] #812507 05/18/07 10:49 AM
P
pcc Offline
Drivers side, behind front bumper, below left side of headlight, right next to the bumper bump-out piece. Wire and connector runs down between headlight and right side of grill. Manual says to remove grill for removal access. There is a test procedure if you need one.
Re: Temperature Gauge Sensor Location? [Re: pcc] #812508 05/19/07 06:19 PM
Thanks. Sounds like it?s well located to avoid false readings. The altimeter seems to be pretty much on the money too.
PHP: 7.4.33 Page Time: 0.022s Queries: 15 (0.019s) Memory: 0.6056 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-11-19 23:53:56 UTC
