sensors #812556 05/17/07 03:52 PM
bombardj1 Offline OP
I am a little confused ok a lot!!! I am thinking on replacing the front o2 sensor, ok they have so many types most are splice in, my book tells me there is a difference from the upstream and downstream, the one the sell aftermarket don't, plus some are 4 wire and others a 1 wire, I want to replace the front upsteam I think it is a 3 wire. what do I do ? other then buy it from Kia which wants a few fingers for it, I have a 2001.
Re: sensors [Re: bombardj1] #812557 05/17/07 03:56 PM
Hydra747 Offline
I ordered from kia @ about $80.00 each a while back. It turned out that all I had to do was spray some electrical cleaner/degreaser on the wire connectors for the second bank <img src="/forums/images/graemlins/confused.gif" alt="" /> But it is imperative to get the bank 0ne changed if needed. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: sensors [Re: bombardj1] #812558 06/13/07 09:15 AM
melody Offline
[color:"green"]check your kia oxygen sensor if it really needs a replacement.. you can try to grease or clean up your sensors, but if it is defected or broken it would be best to have it changed. [/color]
Re: sensors [Re: bombardj1] #812559 06/13/07 02:13 PM
I replace the upstream then a week or 2 the down stream went. it has 106000 miles and I see it things go bad after 100000, gee maybe thats why new cars give 10year 100000 mile sounds great when you buy new <img src="/forums/images/graemlins/kewl.gif" alt="" /> but come to the 100000 and the dealer tells you it's up now to repair it will only cost you money just like the song, then you go from <img src="/forums/images/graemlins/kewl.gif" alt="" /> to this <img src="/forums/images/graemlins/scared.gif" alt="" />then this <img src="/forums/images/graemlins/angry.gif" alt="" />tyhen this to the dealer <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> LOL
Re: sensors [Re: bombardj1] #812560 06/13/07 02:18 PM
Hydra747 Offline
Now you catching on!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
Yep!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: sensors [Re: bombardj1] #812561 06/13/07 08:37 PM
Axe Man Offline
Kia Moderator Emeritus
Both O2 sensors are 4 wire. One wire sensors will NOT work. And yes, the front and rear are different part numbers. Some have had good luck using universal 4 wire O2 sensors in both locations. You can roll the dice and try it and if it doesn't work use a factory original part.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6100 MB (Peak: 0.6980 MB) Data Comp: Off Server Time: 2026-06-22 06:04:04 UTC
