Drivetrain Oil? #812618 05/17/07 07:44 PM
89montero Offline OP
How often do you change the oil in the transfer case, rear LSD, front diff and auto trans?
1989 Montero 4dr V6 3.0l
Re: Drivetrain Oil? [Re: 89montero] #812619 05/17/07 08:04 PM
Scottie2113 Offline
auto trans, 100k miles
gear oils, maybe twice as often, but 100k miles won't hurt either, it really depends on how much dirty muddy water crossings driving you do with it
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Drivetrain Oil? [Re: Scottie2113] #812620 05/18/07 12:47 AM
sparkem Offline
I do my trans once a year, usually diffs every year. Or if I get water in anything, I change it right away. My trans broke around 210k miles though, nice clean good fluid, not a dirty spot on the filter.
Re: Drivetrain Oil? [Re: 89montero] #812621 05/18/07 04:17 PM
W
Winston Offline
Every 30k miles.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: Drivetrain Oil? [Re: Winston] #812622 05/18/07 05:58 PM
sparkem Offline
I was also thinking 30k.
Re: Drivetrain Oil? [Re: sparkem] #812623 05/19/07 04:48 PM
A
Altuve Offline
I change all the fluids once a year, coolant, diff and gearbox oil, transfer, brake fluid, steering, it's cheap insurance. I make 20.000 - 25.000 miles a year...
Montero 98, 5sp manual, Leaf Sprung, SWB, 3.0 V6 engine 12valve, 32" Kumho MT, custom bull bar, custom snorkel, 3 inch lift, KC highlight, 4.625 gears, 1.925 Low, part time 4WD non super select or active trac.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.6099 MB (Peak: 0.6791 MB) Data Comp: Off Server Time: 2026-10-24 23:55:48 UTC
