Dash Board Bling Bling.....or I'm just a geek. #812717 05/18/07 05:24 AM
CORunner93 Offline OP
So...I finally got sick of the stock "idiot" gauges....and decided to update my gauge cluster. I bought a used one at a junk yard, some aftermarket gauges and started cutting. Here is the progress so far.....
It's all wired up and all the gauges work!....even the glow faces on the aftermarket gauges work.
Next, I have to modify the cluster face plate so the gauges look like they were meant to be there. I plan on cutting out around the new gauges and then using some thin plastic (almost a film) to fill in the "gaps".....then glue it into place.
Here's what it looks like so far....
I've also got some aftermarket white "reverse glow" gauges faces ordered for the Speedo, Tach, and gas gauge. That will make all the gauges white face and make it all look like it came that way from the factory....atleast during the daylight hours.
The only problem is that the new faces for the stock gauges will be "reverse glow".....while the aftermarket oil pressure, water temp and battery gauges all have blue glowing faces. I couldn;t find any white glow face gauges for a 2nd gen 4Runner though. Anyone know where I can get some?
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: Dash Board Bling Bling.....or I'm just a geek. [Re: CORunner93] #812718 05/18/07 05:40 AM
Ohhh....and the coolest part.....It's a straight plug in. No re-wiring....outside of the gauge cluster housing anyway.
Just change the oil and water temp sensors, with the ones that came with the gauges.
Re: Dash Board Bling Bling.....or I'm just a geek. [Re: CORunner93] #812719 05/18/07 07:06 AM
Vanishing_Point Offline
I like it. Clean, proffessional install. What about the gas gauge? The sender will probably be a different ohm range.
America's first fourwheel drive was built in Mankato, MN by Ernest Rosenburger in 1908 who founded Four-Traction Auto Co. on Hickory Street. The company though successful closed in 1913.
Re: Dash Board Bling Bling.....or I'm just a geek. [Re: Vanishing_Point] #812720 05/18/07 02:24 PM
Yeah...Couldn't find a a gas gauges that looks like the other aftermarket gauges. I actually couldn't find an aftermarket gas gauge at all. But...I'll live. With the white face it will match the other gauges close enough.
Re: Dash Board Bling Bling.....or I'm just a geek. [Re: CORunner93] #812721 05/18/07 02:29 PM
Adam F Offline
Why didn't you just buy a factory SR5 cluster and swap it in?
97 4R, stock, daily driver
Re: Dash Board Bling Bling.....or I'm just a geek. [Re: CORunner93] #812722 05/18/07 02:30 PM
RatLabGuy Offline
Rather than cut the faceplate, which looks liek it might be awkward sicne you have some round pegs and squares holes <img src="/forums/images/graemlins/drunk.gif" alt="" />, you might be able to get a sheet of thin plastic and just make your own plate. Then you could easily mount and position them whereever you'd like.
Question Reality.
Re: Dash Board Bling Bling.....or I'm just a geek. [Re: CORunner93] #812723 05/18/07 03:05 PM
OOP'S Offline
Did you look here:
http://www.egauges.com/default.asp?Cart=
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Dash Board Bling Bling.....or I'm just a geek. [Re: Adam F] #812724 05/19/07 01:34 AM
My truck is an SR5 with the SR5 gauge cluster.....But the factory gauges are not much more than idiot lights. I wanted gauges that actually gave measured readings....and I didn't want a bunch of add-on, bolted to the top of the dashboard gauges.
Re: Dash Board Bling Bling.....or I'm just a geek. [Re: RatLabGuy] #812725 05/19/07 01:40 AM
That's exactly what I'm planning on doing.
Re: Dash Board Bling Bling.....or I'm just a geek. [Re: CORunner93] #812726 05/19/07 03:57 PM
E
EWong Offline
Autometer makes a calibratable fuel level guage (or one that also comes close)
Im planning on someting similar for my Gen 1
I just did a SR5 swap..
a) the oil pressure guage is WORSE than an itiot light
b) sthe stock OP idiot light reads at 4lbs... DOH
c) the WT guage is night on useless...
d) the Volt Meter is um... useless
e) the TACH is "lazy" and innaccurate compared to my former Autometer Monster tach...
Ive kinda landed on "digital" for the volt meter (and ammeter via a shunt)...
2-1/8" guages should fit.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6400 MB (Peak: 0.7645 MB) Data Comp: Off Server Time: 2026-06-22 06:13:25 UTC
