Engine RPM's @ Speed
#812773
05/18/07 03:59 PM
I just installed an aftermarket Tach on my truck, but im a little skeptical about what its reading. So I was wondering if this sounds accurate-
2300 @ 70mph in 5th 1600 @ 30 in 3rd and it says im idling around 600
My guess is that its off by a few hundred rpms somehow, because the truck sounds fine at idle, and at speed, when i hear the motor it doenst sound accurate to the tach.
BTW it has 3.56 gears, and 225/75/15 tires. Thanks for any input <img src="/forums/images/graemlins/cheers.gif" alt="" />
1998 Tacoma Xtra 4x4 2.7 5 Spd
Re: Engine RPM's @ Speed
[Re: MaineDrummah]
#812774
05/20/07 01:32 AM
I've got an automatic w/4.10 gears, but 265/70-16 (~31")tires, and my truck turns about 2100rpm at 70mph, and idles (fully hot) at around 600-650 with the A/C off.
You've got taller gears, but smaller tires. I couldn't find the specs on the differences between the 5th gear ratio in your tranny and the O/D ratio in my automatic, but the rear-end gears versus tire size should make your driveshaft turn about 6% slower than mine at the same road speed. Again, the top gear ratio differences between the tranmissions could change your actual difference in crankshaft speed up or down from this 6%.
Another possible difference is in our speedometers -- I've checked mine with a GPS and it's pretty close. At 70, a 4mph difference in speedo's could erase the tire/gear differences above.
That said my guess is your tach is at least reasonable.
[Re: MaineDrummah]
#812775
05/22/07 05:44 PM
OK your engine redlines at 5750 RPM.. if u want to be daring let it hit the limiter and see where the needle stops at... then u can tell if youre off..
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
[Re: Greg_Canada]
#812776
05/25/07 06:30 AM
Good suggestion to redline my motor, but I did the next best thing. Took it off because who needs it anyways <img src="/forums/images/graemlins/smile.gif" alt="" /> I did put on 4 new 30 X 9.5 Toyo Open Country AT's and changed all gear oils to syntheic though today. What a difference in shifting and ride. Cheers for the replys though <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: MaineDrummah]
#812777
05/26/07 11:51 PM
Oh yeah, i forgot to put a <img src="/forums/images/graemlins/ignore.gif" alt="" /> in my post... heh...
WHo needs a tach? They're nice to have....
