Alternate amplifier locations #813009 05/18/07 09:58 PM
bradford_johnson Offline OP
IÆm trying to find a location to mount an audio amplifier for an audio upgrade in my 2004 TJ. I want to remove the carpets for some wet weather so under the seats is no good, and I have an add-a-trunk in back so there is no room there. Has anybody ever tried mounting an amplifier behind the dash?
2004 TJ Wrangler Sport
Re: Alternate amplifier locations [Re: bradford_johnson] #813010 05/19/07 02:08 AM
Brown81CJ5 Offline
What kinda system do you plan on running? If not too big a one, you can get a fairly small amp and get like a 1 farad capacitor...2 items, but easier to find spots for 2 smaller items.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Alternate amplifier locations [Re: bradford_johnson] #813011 05/19/07 04:54 PM
Macdaddy4738 Offline
behind the dash isnt a good idea...you still get some small water leaks back there (at least in the older TJ's, not 100% sure about the newer ones)
do you take your doors off alot? you might be able to rig it up to go into your door (there is a bit of room behind the panel)
Re: Alternate amplifier locations [Re: Macdaddy4738] #813012 05/19/07 05:03 PM
Brown81CJ5 Offline
What size is the amp that you have or are planing on getting. If it's small enough you could put it in your center console if you have one....sorry I have a CJ, not a TJ...just tryin to throw some ideas out there.
Gun it and run it!
Re: Alternate amplifier locations [Re: bradford_johnson] #813013 05/19/07 09:44 PM
Chris72 Offline
Would it be sheltered enough if you mounted it under the seat, but instead of on the floor, mount it to the bottom of the seat itself?
Re: Alternate amplifier locations [Re: Chris72] #813014 05/22/07 04:38 AM
kornblind9 Offline
Yeah...There should be room to mount it under the back seats. That is where i mounted my JL amp
'98 TJ, Manual, 3" Susp and 1" Body lifts, 33" BfGoodrich Mud Terrains, Winch, JET Stage 1/2 Power Module Computer Chip
Re: Alternate amplifier locations [Re: kornblind9] #813015 05/27/07 01:32 AM
G
Greg_Canada Offline
How about getting a marine amp?
89 4Runner
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6156 MB (Peak: 0.6887 MB) Data Comp: Off Server Time: 2026-07-13 03:42:03 UTC
