starting to install lift
#813074
05/19/07 03:50 PM
finally i have time to install lift i going to start in about ten minutes hopefully everything goes smoothly going to post progress through out the day i have the whole day set aside so i will take my time. <img src="/forums/images/graemlins/patriot.gif" alt="" />
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
Re: starting to install lift
[Re: kiarazy]
#813075
05/19/07 07:29 PM
so driver side is done and it went pretty good, the passenger side should go a little faster now that i have done it once and everything on that side has been soaking for a couple of hours with liquid wrench
[Re: kiarazy]
#813076
05/20/07 06:00 PM
finished yesterday at 6 pm the rear took some time because i put daves shock relocation in so there was some grinding and welding involved will try to get pics on by the end of the day <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: kiarazy]
#813077
05/21/07 04:02 AM
[Re: kiarazy]
#813078
05/21/07 11:11 AM
nice work! <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: blitz]
#813079
05/21/07 03:59 PM
i apologize for not typing out your instructions, i am glad you figured it out ok. just curious, was it the plates on the x-member you had to grind so they'd fit between the frame rails? or something else?
looks good, hope you have fun. looks like it might need a little 1/2-1" spacer out back, though....
just my .02.
95 Sportage w/welded and 5.89 geared dana 44's on 38.5" TSL's.- SADLY SOLD CURRENTLY - 2000 sportage, 5.38 gears, welded diffs, 35" tires, 5.5" lift http://www.cardomain.com/ride/341410
[Re: Dave Scott]
#813080
05/22/07 03:27 AM
just my .02. the only thing i had to grind was the spots were i was going to weld, the crossmember was tight but i just pounded it in as for the rear yea those tj springs just didn't get me the right hight so i will be trying something else
[Re: kiarazy]
#813081
05/22/07 03:48 AM
im curious about the relocation for the shocks at the back. I went and played around out behind the house, and at full articulation, just as the wheel was leaving the ground, i looked at the opposite side and with the rocksport springs in there, they are completely compressed as it is. will it even be possible to get more out of it by moving the shocks? i am curious because, it is already time to replace my shocks in the rear, and if it will help i will do the relocation and get the different shocks for it.
thanks.
P.s. That front stinger style bumper is kick ass!!!
[Re: kiarazy]
#813082
05/22/07 01:01 PM
just my .02. the only thing i had to grind was the spots were i was going to weld, the crossmember was tight but i just pounded it in as for the rear yea those tj springs just didn't get me the right hight so i will be trying something else couple things- the lower coil retainers (half round tube pieces)- where'd you weld them and how? they were meant to go on the lower coil seats, one end on the nub in the center and the other end on the lower surface plate where the coil sits, welded in place. the best place to put them is on the inside facing sides of each coil plate. i'm just wondering where you put them. i see you got the bumpstops in the right place. and for defboy- the way you get more wheel travel with this kit is mainly in extension, not further compression. putting the shocks at an angle means they extend less for the same amount of axle droop, so you can just keep extending until the shock runs out or something else, like brake cables, pulls tight. back to kiarazy- one note on your bolts for the x-member- turn them around or you might tear holes in your tire sidewall when you flex it up. because the kit allows a lot more droop, your stuffed tire will tip more, when it tips, it gets very close and may rub the frame, those threaded ends of the bolts may stick out enough to cut the tire.
[Re: kiarazy]
#813083
05/22/07 10:03 PM
Did you get your TJ springs of a soft or hard top. My TJ springs gave me allmost 4 inches exactly but I don't know if they were form a hard or soft top. Your Kia looks great by the way and with your rear shock relocation kit you will get awsome travel, that the next thing I would like to do to my boys. I'm trying to talk him into saleing it back to me. Dennis
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
