Page 2 of 3 1 2 3
Re: starting to install lift [Re: DennisThompson] #813084 05/23/07 02:13 AM
kiarazy Offline OP
i welded the bottom coil retainers straight out the back and laid them flat but up tight to the nub all i did is spun the spring till it centered if you look close in the picture you can see the left one, as far as the tj springs they were off a hard top and i only measured 2 inches of vertical lift after i installed them i don't know what i got out of the front because i thought about measuring it after i had the jack stands underneath and tires off. But the rear ones could be wore out i do have accsess to another set so i will try those next
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
Re: starting to install lift [Re: kiarazy] #813085 05/23/07 06:25 PM
logansportage Offline
Nice Rig!!!
Re: starting to install lift [Re: kiarazy] #813086 05/23/07 06:57 PM
DennisThompson Offline
In your pics you rear springs look like they are compressed more than mine and mine is a 4 door. Try the other set and if they are the same I have a set of 1 1/2" or 2" spacers if you want a little more lift.
Dennis
Re: starting to install lift [Re: DennisThompson] #813087 05/23/07 10:34 PM
MemphisFred Offline
OK, am I missing something? Where are his pics?
No matter where you go, there you are!
"Buckaroo Banzai"
Re: starting to install lift [Re: MemphisFred] #813088 05/23/07 10:38 PM
Hydra747 Offline
Prolly need to check your video memory....... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: starting to install lift [Re: DennisThompson] #813089 05/24/07 03:08 AM
kiarazy Offline OP
Dennis
ok yea i will let you know when i get around to trying those other springs
Re: starting to install lift [Re: kiarazy] #813090 05/25/07 10:27 PM
V
victwisted Offline
Kiarazy,were did you get your bumper????F/R,They look great>>I need them<<<< <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" />
99' sportage,4"lift RSG,31" M/T Baja MTZ on DC1 rims,custom 1 3/4" body lift, one dog,one cooler,one heavy foot,maps, and the will to wheel my kia with the rest of the offroad world
Re: starting to install lift [Re: victwisted] #813091 05/25/07 11:00 PM
Hydra747 Offline
Ya, me too!!!
Re: starting to install lift [Re: victwisted] #813092 05/25/07 11:56 PM
DEFBOY35 Offline
i may be wrong, but by the looks of it, it is a jeep bumper. if so i was going to do the same thing. all you have to do is rework some mounts for it to fit the sportage.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: starting to install lift [Re: DEFBOY35] #813093 05/28/07 08:55 PM
kiarazy Offline OP
custom i made them myself its 2x6 rectangular tube, then on the front i bent the hoop on a buddies bender they were preety easy to make and i got 75 bucks in to them that included the tubing for the rock slides.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6454 MB (Peak: 0.7658 MB) Data Comp: Off Server Time: 2026-06-20 23:02:17 UTC
