Gen 1 - Front Hub Lock Nut Wrench? #813221 05/20/07 01:25 AM
RichSmith Offline OP
Where can I get a Front Hub Lock Nut Wrench to remove the hubs from my '87 Montero. I need to replace wheel bearings.
Service Manual says: Special Tool No. MB990954
Local Napa & Shucks guys can't identify it. Can anybody tell me what I need to ask for? I've never seen one so I can't describe it to them.
Rich Smith
Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: RichSmith] #813222 05/20/07 01:34 AM
FrankR Offline
Try a search for it - some have used a 3/4 ton Ford or GM (don't remember which) 6 tooth hub socket... you have to grind off 4 of the teeth. The specific application tool is about $70 and not worth the price if you can find the alternative. If you can't find the alternative, I'll mail you mine to use for postage.... but for the price of postage, you can probably buy the alternative tonight from PepBoys or AutoZone, grind 4 teeth off and fix the truck tomorrow.
Frank
Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: FrankR] #813223 05/20/07 01:36 AM
sparkem Offline
If you really have to do it now, cant wait, it can be done with a hammer and punch.
Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: RichSmith] #813224 05/20/07 02:22 AM
dwehbie Offline
I bought a really big pair of curver needle nose plyers that have a long handle. They spread wide enough to fit the holes. Works great.
1996 Toyota T100
Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: FrankR] #813225 05/20/07 02:27 AM
CapnCrunch Offline
...some have used a 3/4 ton Ford or GM (don't remember which) 6 tooth hub socket... you have to grind off 4 of the teeth.
IIRC, mine is a 3/4 ton GM socket. Ground off 4 of the teeth. <img src="/forums/images/graemlins/shiner.gif" alt="" /> It's a little cumbersome to use (tends to slip off) but it gets the job done.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: sparkem] #813226 05/20/07 02:53 AM
Jamez Offline
I bought the GM one for something like $16 and just grinded all but 2 of the pegs off.
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: RichSmith] #813227 05/20/07 04:00 AM
Thanks Guys,
I can handle grinding off 4 of the 6 lugs. KD Tools lists one with and O.D. of 2.60". Is that about right?
(Frank, thanks for offering to mail yours but it looks like I'm getting it worked out here pretty fast.)
Rich Smith
Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: RichSmith] #813228 05/20/07 04:02 PM
I have a K-D. I'll check for a part # today while I'm boat wrenching...
Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: RichSmith] #813229 05/20/07 04:19 PM
powerRam50 Offline
to bad you were not a little closer,i would let you use mine.
Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: powerRam50] #813230 07/18/07 05:51 PM
G
generation_one Offline
For torquing down the hub nut, Torque it 94-145 ft.lbs., then back it off to 0 ft.lbs., then retorque it to 18 ft.lbs., then back it off 30-40 degrees.
Ahh...so that's why they call you captain crunch
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6392 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-06-07 06:08:00 UTC
