Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: RichSmith] #813231 07/18/07 07:09 PM
english_redneck Offline
I made a tool to do my 1989 MK1 Pajero (i'm assuming that's the same as a Montero), it's fairly easy to do if you have access to welding gear.
The dimensions for the tool is 60mm between dowel centres (i used M10x90 bolts with the ends ground down to fit the holes) I used a bit of box section approximately 40x15mm 120mm long and welded an old socket to that. Sorry the dimensions are metric.
Re: Gen 1 - Front Hub Lock Nut Wrench? [Re: english_redneck] #813232 07/18/07 07:31 PM
CapnCrunch Offline
I made a tool to do my 1989 MK1 Pajero (i'm assuming that's the same as a Montero)...
Yes, an MK1 Pajero, a Gen I Montero, and a Dodge Raider (2-door only) are all synonymous.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
PHP: 7.4.33 Page Time: 0.005s Queries: 16 (0.004s) Memory: 0.5947 MB (Peak: 0.6594 MB) Data Comp: Off Server Time: 2026-05-29 14:59:18 UTC
