What would you do? / Would any one be interested? #813250 05/20/07 07:07 AM
DangerCart Offline OP
If i'm violating any rules here please let me know.
My truck had a camshaft seize. Opening up a whole can of worms. I've done a bit of prep work, but now do I want to continue further? The only way I see this thing being fixed is to rebuild it. Unfortunately I don't have the time,place or money to do a complete rebuild. And i'm not sure if I want to do just the heads and leave myself open for more problems. (anyone here redo the heads on a high mile 3.0 sohc?)
If I do decide to get rid of it I would at least want it to go to someone like the people here. I think there is plenty of life left in this truck however I might not be the person to do it.
1989 Dodge Raider 3.0L with 5-speed.
In limbo of what to do with it.
Re: What would you do? / Would any one be interested? [Re: DangerCart] #813251 05/20/07 04:00 PM
Put good heads on it and pray, IF:
oil pressure was good
compression seemed good (or check it with the bad head if the valves seal - no cam necessary - compression pressure will be low initially because must use cylinder vac to lift intake valve off seat - extended cranking will make high cyliner pressures - no exhaust opening...)
I spent $600 on a set of rebuilt heads on a 265k motor...
Re: What would you do? / Would any one be interested? [Re: fasteddy] #813252 05/20/07 04:14 PM
Oil pressure was normal when it went, And continued cranking oil pressure would clime to normal levels.
Hmm....
Re: What would you do? / Would any one be interested? [Re: DangerCart] #813253 05/20/07 10:52 PM
sasnydley Offline
Did mine at 240k. bout 600 with my labor. still going now. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6023 MB (Peak: 0.6582 MB) Data Comp: Off Server Time: 2026-11-03 04:53:03 UTC
