How warm does your rear axle get?
#813270
05/20/07 03:53 PM
Recently replaced a leaking seal on my rear diff. After a test drive I crawled back under to check, and the leak appears fixed, but the axle housing was quite warm. Have to admit I have never put my hand on it before after driving, so not sure how hot it should be, but was surprised just how warm it was.
Re: How warm does your rear axle get?
[Re: trickster]
#813271
05/20/07 04:40 PM
Its normal to get warm, sometimes even hot. Just a lotta friction in there.
[Re: Scerb]
#813272
05/20/07 04:53 PM
Quote from one of the best gearman around, especally for rockcrawling.
"norm op temp is 125 to 175 if the paint burns off the diff its to hot"
"Serenity through Sobriety"
[Re: OOP'S]
#813273
05/20/07 05:17 PM
Thanks guys, thats the answer I was hoping for. Guess I will relax and stop worrying.
[Re: trickster]
#813274
05/21/07 03:28 AM
check the dif. vent.if its clogged it wont make it hot but it will blow oil out the seal when it gets hot.
oh what a feeling: #1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered #2 86 sr5 4x4 efi parts truck #3 87 2wd parts truck 84 supra yard art
[Re: trickster]
#813275
05/21/07 03:42 AM
So did you service it after you fixed the seal? Yeah, make sure that breather is clear. A clogged one is what generally blows the seals in the first place; it allows the gases that build up in the tube to expel; science in action.
[Re: kewlynx]
#813276
05/21/07 04:16 AM
Cleaned the breather a couple weeks ago when I first notice the leak, it was pretty clogged, may have been the cause. Had hoped that just clearing it would stop the leak, but it continued, hence the repair, which seems to have fixed things.
