recarpeting #813369 05/21/07 02:24 AM
CPOM Offline OP
Hey anyone here recarpeted a truck? Mine carpet has holes in it and mold from when it got wet. Can I just use flat carpet or does it have to be like molded to the floor?
CHRIS
98 Amigo, 92 Pup
Re: recarpeting [Re: CPOM] #813370 05/21/07 02:52 AM
Richard Saylor Offline
It's going to be a whole lot easier if you find the premolded stuff. While you could use the flat stuff, it more than likely won't look and work as well as the premolded.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: recarpeting [Re: Richard Saylor] #813371 05/21/07 05:15 AM
Shovel Offline
I recarpeted a Montero (yeah, i know... slightly different) with scraps left over from an office... it sucked, even using the old carpet as a template.
totally worth it to buy the carpet or vinyl from Acc-Mat or whoever.
Or herculine your carpet smile (yes, right on it)
Re: recarpeting [Re: CPOM] #813372 05/27/07 02:43 PM
F
Fujisawa_Rob Offline
I'm trying to find PVC shower pan liner in black. I pulled out the carpet since it was nasty, but those rubber floor covers are a bit pricey for the whole floor (about $200). I'm hoping that if I were to leave the liner in the sun it would get soft enough to "mold" into place, more-or-less.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: recarpeting [Re: CPOM] #813373 05/28/07 03:38 AM
litnin Offline
Non-molded carpet is almost impossible to fit in and
get looking right.
Give Jerry a shout... He sells not only the new factory carpet(super expensive), but he also sells the AutoMat
after-market molded carpets.
He got me one for my '89 Trooper and my '92 Prelude.
They come a little over-sized, but when you lay them in
and cut the perimeter, they fit like a glove.
He could probably get you a pretty good deal on one.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: recarpeting [Re: litnin] #813374 05/28/07 01:32 PM
CPOM Offline OP
I'll just have to find some thin carpet then. When I took it out I noticed the carpet in my pup wasn't molded. It was very thin though.
CHRIS
98 Amigo, 92 Pup
Re: recarpeting [Re: litnin] #813375 05/28/07 05:59 PM
K9Troopin Offline
So are you referring to Jerry Lemond? I'd like to hear some of this too. I cut some outdoor carpet for the front of my Trooper. It seemed to work well but did have a fold or two that can be annoying if you're concered about it. Otherwise it works just fine.
I would prefer to have a vinyl liner if I could too.
Thanks!
Dana
'91 LS Trooper~ 1.5" Susp. & 3" Body Lift, 33"BFG M/Ts, custom double sliders, Indy4x bumper,Herc'd lower body panels, Hella 550 lights, custom rear shelf and speaker box, customized console, blue grill strobe lights and wig-wag headlights
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6189 MB (Peak: 0.6934 MB) Data Comp: Off Server Time: 2026-05-29 19:57:41 UTC
