what is the weight capacity of the rte trucks #813504 05/22/07 01:01 AM
O
oopssorry Offline OP
i know that toyota made some one ton trucks and i was wondering what the rte is. im figuring its probably a 1/4 ton, but i wasnt for sure since it does have a bigger rear axle? i am talking about the 4wd models. and i know the rating is based on spring capacity also. but since i have not found any other info on this i thought i would ask. thanks
1986 toyota pickup rte 4wd sr5 xtracab---bone stock
Re: what is the weight capacity of the rte trucks [Re: oopssorry] #813505 05/22/07 02:04 AM
4Crawler Offline
The GVWR should be listed on the sticker in the driver's side door jamb. My '85 4Runner shows 4800 lbs.:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml
I think the pickups are rated at 1/2 ton.
Re: what is the weight capacity of the rte trucks [Re: 4Crawler] #813506 05/22/07 02:25 AM
O
at least its better than the 1/4 ton i assumed <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: what is the weight capacity of the rte trucks [Re: oopssorry] #813507 05/22/07 04:00 AM
trythis Offline
did you know the RTE is a turbo? At least I think that is what you are talking about.
Re: what is the weight capacity of the rte trucks [Re: trythis] #813508 05/22/07 09:58 PM
O
yes i know, that is what my truck is
Re: what is the weight capacity of the rte trucks [Re: oopssorry] #813509 05/22/07 11:03 PM
Elbow_Greese Offline
The frame isself is the same one they use in the 1ton trucks, but the springs are only 1/2 ton rated.
Since you already have the 8" rear end, just swapping out the springs for the 1ton rated kind will make your truck capable of hauling that amount.
Bit of caution though, they are stiff.
Just a side note, there's a 1ton cab/chassis truck (2wd dually) that's been outfitted as a tow truck in Michigan City, IN.
Fun to see!
I'll see if I can grab a pic at some point.
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: what is the weight capacity of the rte trucks [Re: Elbow_Greese] #813510 05/23/07 01:05 AM
O
i would like to see that if you can find it. thanks for the info also
Re: what is the weight capacity of the rte trucks [Re: oopssorry] #813511 05/23/07 01:45 AM
trythis Offline
Well make yourself a sig instead of keeping us guessing <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: what is the weight capacity of the rte trucks [Re: trythis] #813512 05/23/07 02:41 AM
Dingman Offline
Hmm, I sold my '83 pickup to my roommate who occasionally gets a load of gravel for the driveway. He loads it up to about 1200 lbs and it doesn't squat to badly and drives OK. So, 1\2 ton is about right, based on what we see here.
Paved Roads ~ Another example of wasteful government spending.
'85 $runner, lifted and locked.
See the Ding_yota here
Re: what is the weight capacity of the rte trucks [Re: oopssorry] #813513 05/23/07 03:01 AM
foxtrapper Offline
Just to help with the confusion that Toyota created.
The 1-ton is 2wd only. There was never a 4wd 1-ton made.
Dualies were not standard on the 1-ton. They were an option available to any truck.
The above words are pre-Tacoma and T100 era.
'97 T-100 SR5
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6401 MB (Peak: 0.7626 MB) Data Comp: Off Server Time: 2026-05-29 15:17:25 UTC
