Yes, *another* 91 V6 HVAC blower question #813721 05/23/07 12:06 AM
Shovel Offline OP
I searched.... read dozens and dozens of posts...
2 questions I haven't been able to conclusively answer:
  • Where exactly is the oil pressure switch relating to HVAC function?
  • Is there a fuse or something in the resistor pack that would stop the fan from blowing at ANY speed (incl no high speed) ?
Also, does anyone have a photo of the 2 relays under the dash? I was only able to find one relay under there.... but there are like 15+ unused or disconnected wire harness connectors dangling around various parts of the dash... no way to know which ones are for options my truck never had and which ones are actually disconnected and should have something on 'em
Thanks!
(BTW I can at least eliminate the possibility that the relay behind the left headlight is bad.... THAT one was easy to isolate and test... 80 ohms across trigger, trigger clicks, and continuity on switched contacts when it is triggered.)
Re: Yes, *another* 91 V6 HVAC blower question [Re: Shovel] #813722 05/23/07 12:26 AM
Richard Saylor Offline
If your fan is not working all together, and you're sure that it still works, then most likely you blew the fuse for it. That fuse is located underneath the steering column and is taped up in the wiring harness. Just have to kinda dig for it. Personally, I think it's stupid for it to be there. Why not put it in the fuse box where it belongs?
Not sure which oil pressure switch you're talking about. To my knowledge, there isn't one for the a/c oil. There is however one for the pressure itself inside the lines. That one is located on the dryer itself.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Yes, *another* 91 V6 HVAC blower question [Re: Richard Saylor] #813723 05/23/07 02:11 AM
Shovel Offline OP
ahh... found it...
the 2nd relay, the black one by the gas pedal - was just not even there. FPO! I borrowed the "warning light relay" one from under the hood, plugged, in, and the fan works in all speeds now.
So, warning light relay went back to where it belongs and now I have to hunt down a new relay - is this a dealer only part or can i get one from autozone?
Now, the a/c compressor still isn't kicking on.... but I think I'll leave that part to an A/C shop since I haven't the tools or talent to test, vamp, or charge it.
Re: Yes, *another* 91 V6 HVAC blower question [Re: Shovel] #813724 05/27/07 02:48 PM
F
Fujisawa_Rob Offline
Thanks!
It's the same oil pressure switch that controls the fuel pressure back-up relay, the one mounted right next to the filter. I don't know why GM did this, it's weird. It prevents you from running the blower if the engine is off, even if the key is in the ACC position. There is a TSB on this, as the original ETM/Service manual had it wrong in the wiring diagrams. If you have the Alldata CD, it's in there. SB90-04-007 "A/C Compressor - Wiring Circuit, Manual Correction".
Glad you got yours working. The problem I had is that my original oil pressure switch was leaking through the connector. Even after I replaced it, my blower was still flaky. I cleaned the contacts on the switch and connector and voila! It works fine now. The blower is a bit weak though.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6040 MB (Peak: 0.6773 MB) Data Comp: Off Server Time: 2026-05-29 17:28:46 UTC
