lifter noise
#813731
05/23/07 02:08 AM
Hi have a 1996 3.2L V6 Trooper / Jackaroo (Oz) sounds like a sick diesel so far have replaced Timing belt,Lifters & Oil Pump starts off very quiet in morning by end of day a sick diesel have run out of ideas on what to try next
Thanks
Re: lifter noise
[Re: MarkOz]
#813732
05/25/07 08:46 PM
did you replace the gas-charged tensioned when you did the timing belt? not sure about the fact that it starts off quiet in the morning, but that's a pretty common cause of a knocking noise. Did you buy all brand new lifters? <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: lifter noise
[Re: MarkOz]
#813733
05/26/07 08:24 AM
G'day fom a fellow Jackaroo owner. Mine is a '97 3.2V6 and I haven't (yet) experienced this problem but I have noted several threads about it on various forums: Some are listed at http://forum.australia4wd.com/index.php?showtopic=7667From new I have always used Castrol engine oil - either GTX3 or Magnatec - so far OK. I presume that you have experimented with oils?
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5899 MB (Peak: 0.6429 MB) Data Comp: Off Server Time: 2026-06-13 10:55:31 UTCValid HTML 5 and Valid CSS
