lifter noise #813731 05/23/07 02:08 AM
MarkOz Offline OP
Hi have a 1996 3.2L V6 Trooper / Jackaroo (Oz)
sounds like a sick diesel
so far have replaced
Timing belt,Lifters & Oil Pump
starts off very quiet in morning by end of day a sick diesel have run out of ideas on what to try next
Thanks
Re: lifter noise [Re: MarkOz] #813732 05/25/07 08:46 PM
trainwreckr Offline
did you replace the gas-charged tensioned when you did the timing belt? not sure about the fact that it starts off quiet in the morning, but that's a pretty common cause of a knocking noise. Did you buy all brand new lifters? <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: lifter noise [Re: MarkOz] #813733 05/26/07 08:24 AM
boritz Offline
G'day fom a fellow Jackaroo owner.
Mine is a '97 3.2V6 and I haven't (yet) experienced this problem but I have noted several threads about it on various forums:
Some are listed at http://forum.australia4wd.com/index.php?showtopic=7667
From new I have always used Castrol engine oil - either GTX3 or Magnatec - so far OK.
I presume that you have experimented with oils?
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5918 MB (Peak: 0.6448 MB) Data Comp: Off Server Time: 2026-06-10 00:10:19 UTC
