Wheel bearing coming loose #813761 05/23/07 03:48 AM
4
4x4_YOTA Offline OP
Need help. This is the second time I removed, hub, etc. to re-tighten the two 54mm nuts that hold my bearing in place. I followed the FSM and that didn't help. I also followed 4x4wire on knuckle rebuild, i.e.,tighten, turn left, turn right, etc. That didn't help. The bearings and races are in good condition. Re-packed them when I did knuckle rebuild. Got the drag to 12ft lbs. What am I missing here before I try for the 3rd time? Thanks. <img src="/forums/images/graemlins/confused.gif" alt="" />
if u ain't 4 wheelin, whats the sense...
Re: Wheel bearing coming loose [Re: 4x4_YOTA] #813762 05/23/07 04:04 AM
4Crawler Offline
Are you bending the tabs on the star washer in and out to lock the two nuts in place?
Re: Wheel bearing coming loose [Re: 4Crawler] #813763 05/23/07 04:20 AM
kewlynx Offline
x 2; keeps 'em from walkin' off.
**ubi apis- ibi salus**
Re: Wheel bearing coming loose [Re: kewlynx] #813764 05/23/07 05:09 AM
ErikB Offline
Toyota Moderator
And do you have the large single-toothed thrust washer between the bearing and nuts too? It should go: outer bearing, big flat washer, nut, lockwasher, nut. Then bend the tabs on the lockwasher forward/backward on the inner and outer nuts. How tight are you tightening the outer nut?
http://home.4x4wire.com/erik
Re: Wheel bearing coming loose [Re: 4x4_YOTA] #813765 05/23/07 05:17 AM
ZUK Offline
Whats the back spacing on your wheels? and are you using BIG wheel spacers?
mostly stock
Re: Wheel bearing coming loose [Re: ErikB] #813766 05/23/07 05:18 AM
4
4x4_YOTA Offline OP
thanks guys. yup, yup & yup. Tabs bent in and out. 12 lb drag. outer nut is around 60ft lbs. This is so baffling...I can't think of anything else... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Wheel bearing coming loose [Re: ZUK] #813767 05/23/07 05:20 AM
4
4x4_YOTA Offline OP
zuk, not sure at this time of back spacing. its a new ride for me. I do know its american racing, 15x8, with 32's. no spacers..
Re: Wheel bearing coming loose [Re: 4x4_YOTA] #813768 05/23/07 10:05 PM
ZUK Offline
is there a chance the races are not pressed in all the way?
Upon re-reading your post, it looks like you only re-packed them so they should be all the way on....
mostly stock
Re: Wheel bearing coming loose [Re: 4x4_YOTA] #813769 05/24/07 01:26 AM
W
Whizkidder Offline
Are you sure the tab in the center of your star lock washer is long enough to positively grab the machined groove in the threads so it won't turn on the shaft? I have seen one that somehow walked it's way out of the groove and into the bottom of the threads... Good luck! <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Wheel bearing coming loose [Re: ZUK] #813770 05/24/07 09:20 AM
4
4x4_YOTA Offline OP
bearings were only re-packed. I'm checking it out this weekend and will let you guys know. Mahalos.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6428 MB (Peak: 0.7630 MB) Data Comp: Off Server Time: 2026-06-07 06:09:40 UTC
