3.4l swap #814204 05/25/07 12:01 AM
rcecv Offline OP
well since this is my first post i'll start off with hello and nice forum .
i just picked up a 95 four runner that has a rod knock i been hearing about every one swaping out the 3.0 v6 to the 3.4l v6 is this a easy swap to do ? and how much would it cost to do it your self vs. a shop? and would it be worth doing the swap i plan on doing a sas swap on it and run 38's with 5.29's i would also like to put a 4.7 gear in the t-case . and help or info any pro/cons
thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
WORLDWIDE PIRATES OF DX! www.wwpdx.com
Re: 3.4l swap [Re: rcecv] #814205 05/25/07 01:17 AM
kewlynx Offline
It starts with a 2" body lift, minimum.
For regearing, check out www.marlincrawler.com
The 3.0 to 3.4 swap is becoming popular here.
Toyota Tech Archive <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: 3.4l swap [Re: kewlynx] #814206 05/25/07 03:38 AM
rcecv Offline OP
thanks for the tip
im liking this forum better than the PIRATE FOURM
Re: 3.4l swap [Re: rcecv] #814207 05/25/07 03:48 AM
kewlynx Offline
Thanks, and welcome! For the most part, your kids should be able to peek over your shoulder here. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I've managed to consolidate most of the info that's been posted here in the past for the swap; just got to tweak it a little more; some good info has come in on this to make it doable.
Best place to start is with fleabay and www.car-part.com to see if you can find a dedicated rig for a donor.
Re: 3.4l swap [Re: rcecv] #814208 05/25/07 02:21 PM
Kutter Offline
http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
Hi,
Pirate can be rough.
See this link for a few pic's and detials of my swap.
Your 3.0 is already broke and you have plans to keep and built the 4runner. To me that is enough reason to do the swap. My swap experience has been nothing but super. I have more that 6000 miles on it without any negative issue. I have taken it cross country on the highway and it is such a much better experience than highway travel with the 3.0 long distance.
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4
1995 4Runner V6 Auto 2WD
Re: 3.4l swap [Re: Kutter] #814209 05/26/07 07:25 AM
rcecv Offline OP
Hi,
nice job ya i picked up the runner cheap because it has a rod knock i just sold my rock truggie and want some thing i could put the whole famliy in i wwas just going to rebuild the 3.0 in it but i have been hearing alot of talk about the 3.4 swap so what a better way to start my plans after that are to put a soild axle under it 5.29's and a 4.7 in the t-case i would like to run 36's to a 38 mtz for the snow i will build tube bumper and rock skids for it also . so now im on the look out for a 98-00 3.4l motor thanks for all the help !
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6122 MB (Peak: 0.6987 MB) Data Comp: Off Server Time: 2026-06-10 01:55:32 UTC
