failed emissions #814551 05/26/07 01:39 PM
A
aptech Offline OP
93 toy p/u 4x4 engnbldr cam 261 valve timing set @ 7intake 9exhaust, engnbldr street head, lc header exuast, k/n air charger, matched injectors. stock plugs. 8mm wires
Failed the smog test for texas for the second time. the numbers are:
High speed Low speed
HC standard 194 mine 113 standard 199 mine 126
CO standard 2.19 mine .33 standard 1.69 mine .44
NOx standard 1258 mine 1474 standard 1378 mine 2205
I replace the EGR valve And the vacumm modulater, thermostat with a 160. i found the vacumm line to the modulator from the egr valve cloggeg. cleaned it up and stuck it back. on. pulled vac on egr valve eng when running at idle and it died so thats good.
What should i do next. i have passed the spending limit for this year 600 dollors so i can be exempt but i'll fail it next year i need to fix this.
thanks for your help
Re: failed emissions [Re: aptech] #814552 05/26/07 09:46 PM
toyotaguy55 Offline
run two cats <img src="/forums/images/graemlins/lol.gif" alt="" />
toyotas look good with body damage
Re: failed emissions [Re: toyotaguy55] #814553 05/26/07 10:28 PM
A
aptech Offline OP
too much hair <img src="/forums/images/graemlins/mrt.gif" alt="" />
Re: failed emissions [Re: aptech] #814554 05/27/07 07:51 AM
ArbitraryNotion Offline
Just checking to make sure you are saying that you drew vac on the valve(opening the valve), not that you simply pulled the vac line off of the valve.
Checked your O2 sensor lately? How bout your TPS? Oh how I hate EFI... grrr... :P
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: failed emissions [Re: aptech] #814555 05/27/07 07:59 AM
Brian894X4 Offline
If you haven't already, try putting in fresh oil and make sure it's nice and hot before you get it tested. Run up and down a freeway a few times, then head to the smog station.
I know that I've failed a few times in the past, because I just drove straight to the smog station from my house, which is about 8 miles in town. But if I got the engine nice and warm with high speed driving, it passed.
Re: failed emissions [Re: ArbitraryNotion] #814556 05/27/07 08:59 AM
A
aptech Offline OP
yes i drew a vacumm on the valve
Re: failed emissions [Re: aptech] #814557 05/29/07 03:42 PM
A
aptech Offline OP
ttt help
Re: failed emissions [Re: aptech] #814558 05/29/07 03:46 PM
4Crawler Offline
To reduce NOx on my '85, I found retarding the ignition timing a few degrees helped, as did running a tank of premium gas (for the test). Also spent a day cleaning and porting out the EGR passages in my header and head plus the EGR plumbing and valve. My EGR would kill the engine with the simple vacuum test, but it seemed that there was not enough flow at the higher engine loads to be effective.
Re: failed emissions [Re: aptech] #814559 05/29/07 10:52 PM
When was your last oilchange?
HC and CO can sometimes be fixed by doing an oilchange right before the test.
Re: failed emissions [Re: aptech] #814560 06/02/07 06:02 AM
mcpree Offline
A 160 thermostat seems a bit low for passing smog, assuming all other systems are operational. I've always put in a 195 for the test then replaced it with the lower temp of choice after passing.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6395 MB (Peak: 0.7625 MB) Data Comp: Off Server Time: 2026-06-07 04:51:10 UTC
