doors off mirror question #814594 05/26/07 10:03 PM
hoki06 Offline OP
im looking to get a mirror so i can stay legal with my doors off and im going back and forth between the Lange Quick-Release Mirrors. the 1st on is the quick-release 1 that goes into the door hinge but i cant see how its secured in there and i dont know how well it would stay. the other is the quick-release 2 that goes on the windshield hinge and i can see that it sits in there fine and it would be secure but its $10 more than the first one. what do you guys think? and if you have a better suggestion like a different brand or something then let me know. thanks
Re: doors off mirror question [Re: hoki06] #814595 05/27/07 12:37 AM
BobRowe Offline
It might help to know what kind of vehicle you're talking about.
Re: doors off mirror question [Re: BobRowe] #814596 05/27/07 03:11 PM
hoki06 Offline OP
sorry its a 90 Wrangler
Re: doors off mirror question [Re: hoki06] #814597 05/27/07 03:53 PM
BigJim Offline
First thing I'd do is see which screws/bolts need to be taken out for the install. I'd go see if they were too tight to take out without a torch! The tightness of these might help me make up my mind.
Re: doors off mirror question [Re: hoki06] #814598 05/27/07 04:14 PM
BobRowe Offline
A couple of different manufacturers make mirrors that attach to the windshield hinges, and they hwork well. I've got a pair made by Kentrol on my CJ and I've been happy with them. Allows me to just lift off my doors and not worry about mirrors.
Re: doors off mirror question [Re: BobRowe] #814599 05/29/07 03:15 PM
DBL_DTY97TJ Offline
I've got the same thing...May not be Kentrol, but they fit in the hinge hole and have a screw clamp to tighten to the frame. Bout 40 bucks each I think. Quadratec had them IIRC. I like them just fine, easy in and out and they were still good after sitting in some pretty nasty water for a couple of months. They vibrate more than the door mirrors, but you get used to it.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: doors off mirror question [Re: DBL_DTY97TJ] #814600 05/29/07 06:42 PM
BobRowe Offline
The ones I have from Kentrol don't mount in the hinge holes. They use the four small threaded holes on the front surface of each hinge. They are basically permanently mounted there, and I don't have to mess with them when I take the doors on or off.
Re: doors off mirror question [Re: BobRowe] #814601 05/31/07 02:50 AM
tomriddle Offline
i invariably forget to take the mirror off the door hinge before i try to put the door on.
get the cheap one...it's just to keep you legal. theres all of four feet of jeep behind you....what do you need to see?
94 yj 456gears, detroit locker and 30 spline axles out back, 33" bfgs
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6218 MB (Peak: 0.6998 MB) Data Comp: Off Server Time: 2026-06-22 06:16:17 UTC
