XJ Air Conditioning #814602 05/27/07 12:13 AM
fresnodb Offline OP
I just bought a '99 XJ. All seems OK but when the engine gets up to normal operating temp, the AC shuts off. Does any one know of a sensor or relay that might be the cause of this problem?
Back in the game!
'94 YJ 2.5 all stock.
Re: XJ Air Conditioning [Re: fresnodb] #814603 05/31/07 02:39 AM
KLRTom Offline
My '98 XJ a/c quits after about 30 minutes because it freezes up. To get it going again, I switch to vent for a few minutes, then I can go back to a/c for a while. It's a little low on refrigerant, but when you refill it it soon leaks back down to the present level. I just haven't had time to fool with it to find out where the leak is.
Re: XJ Air Conditioning [Re: fresnodb] #814604 05/31/07 04:29 AM
BigJim Offline
Yep! DB give it some refrigerant.
Re: XJ Air Conditioning [Re: fresnodb] #814605 06/05/07 03:43 PM
fresnodb Offline OP
Thanks Tom & Jim. Evacuated and recharged. Seemed ok for a while, then woulden't cycle back on. Checked pressures, HI & LOW were extreme opposite of what they should be, indicating a stuck expansion valve. This system does not have a replaceable expansion valve. After a while it worked again. Some say theese vehicles had many intermittent electrical problems. The A/C works more than it doesn't work making it difficult to diagnose which I would gladly pay someone to do if it would stay not working! <img src="/forums/images/graemlins/confused.gif" alt="" />
Back in the game!
Re: XJ Air Conditioning [Re: fresnodb] #814606 06/05/07 03:57 PM
BigJim Offline
Uh, not replaceable? Then it must be CLEANABLE! But to take the system apart you will need to pull a vacuume on the system before recharging.. I'd advise a trip to the A/C guy.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6039 MB (Peak: 0.6681 MB) Data Comp: Off Server Time: 2026-05-29 22:30:20 UTC
