Board at work Part II: "The Return of the Cold Air" #814657 05/27/07 06:14 PM
Iron Offline OP
Finished what i started last week with my quest to get more air into such a little hole!
Long story short, removed ALL stock airbox, filters tubing etc! from the MAF forwards. Clamped on a 6'x3' K&N cone filter. Built a air box using 14 guage stainless to act as a dust/heat shield, the box seals to the hood liner, cut a 2'x5' slot in the wheel arch to draw cool air from underneath and a 1 1/2'x4' slot in the hood and used a small vent cowl painted body colour to act as a rain deflector and to allow the filter to draw cool air in from the top
(If anyone is intrested the KIA body colour "Stone Beige" is a 99% match with GM's LT Brier Brown CDSGM331)
And now the pictures!
[Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image]
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: Board at work Part II: "The Return of the Cold Air" [Re: Iron] #814658 05/27/07 08:04 PM
Everet Offline
Looks SWEET!! Let me know if you see any improvement in fuel mileage. I'm toying with making a snorkel. Speaking of color matches, you have a good one for the white on a 96? Anyway, thanks for the great pics.
Everet <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Board at work Part II: "The Return of the Cold Air" [Re: Everet] #814659 05/27/07 09:55 PM
Hydra747 Offline
Nice work. That takes some guts to initially attempt such an alteration. Right now Im sanding out two deep scratches on the hood and I decided to just make the whole thing black. You know you hit the point of no return---once the first cut is made.
Where did you find that bug deflector?
Re: Board at work Part II: "The Return of the Cold Air" [Re: Hydra747] #814660 05/28/07 01:33 AM
Iron Offline OP
It's a factory one! Came as an option when I bought the Sporty!
08' Jeep Wrangler
58' Triumph TR-3A
Re: Board at work Part II: "The Return of the Cold Air" [Re: Everet] #814661 05/28/07 01:51 AM
Iron Offline OP
I will post any improvements in gas milage next time I fill up! As for increase in low end power, it is quite noticeable, and the engine revs more freely and higher with an increased top speed of 135kph, where as before I was topping out at 120kph.
As for the colour match, I just took off the gas cap door and went into a Canadian Tire, and found the closest match from the selection of rattle can touch-up paint they had, cost $4.99. If I couldn't find a close match i was going to go to the local NAPA, which mixes paint in bombs as long as you have a sample, (gas cap door) they can match it, but they a little more expensive at $29.99
08' Jeep Wrangler
58' Triumph TR-3A
Re: Board at work Part II: "The Return of the Cold Air" [Re: Iron] #814662 05/30/07 09:52 PM
logansportage Offline
Nice!!!
Re: Board at work Part II: "The Return of the Cold Air" [Re: Iron] #814663 10/18/07 10:52 PM
A
agm Offline
where did you get the vent cowl from??
Re: Board at work Part II: "The Return of the Cold Air" [Re: agm] #814664 10/19/07 02:12 AM
Cen_Tex_KIA Offline
Looks great, like a factory option. I understand the hood "scoop", But dosn't venting in the wheel well ask for crappies to get splashed into the filter? I know my wheel wells stay pretty well sprayed with mud! <img src="/forums/images/graemlins/kewl.gif" alt="" />
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6263 MB (Peak: 0.7265 MB) Data Comp: Off Server Time: 2026-06-07 04:40:12 UTC
