3-row radiator in a 1985 Jeep CJ7 #815065 05/28/07 08:51 PM
O
onetoncrewcab Offline OP
Hey guys,
Here is my latest dilema...
My radiator is leaking. It is a two row core. I figured as long as I was going to replace it, I would go with a 3-row core.
It doesn't fit.
I can either have the radiator installed or I can have the fan installed. I cannot have both. I really did not want to install an electric fan either. My plan is to return the radiator and get a 2-row.
Doing a google search, i appears that people are putting these 3-row radiators in. If so, how?
The Jeep had air at one time and I always thought that I was going to hook it up again. That is the only reason I was looking at the 3-row. Oh...it wasn't much more money either.
Mike
Re: 3-row radiator in a 1985 Jeep CJ7 [Re: onetoncrewcab] #815066 05/28/07 10:06 PM
BigJim Offline
Is there a block extension on the fan base? Or does it fit right on the pump without an extension?
Re: 3-row radiator in a 1985 Jeep CJ7 [Re: onetoncrewcab] #815067 05/28/07 10:55 PM
BobRowe Offline
I've got a 3-row radiator on my CJ7, with an engine-diven fan (with clutch) on the AMC360 V8 engine that's in it.
If you can't fit a 3-row radiator there, I suspect that it's a matter of the brand being used. Try a different one.
The brand of my radiator is Modine.
Re: 3-row radiator in a 1985 Jeep CJ7 [Re: BigJim] #815068 05/29/07 12:01 PM
O
Hi Jim,
The extension is made right onto the fan clutch. From the front of the fan clutch to the back where it bolts onto the engine is 3". I was hoping they made a shorter fan clutch, but no luck on that.
Oh...I should have mentioned, this is a 4.2 6-cyl.
Mike
Re: 3-row radiator in a 1985 Jeep CJ7 [Re: BobRowe] #815069 05/29/07 12:04 PM
O
And that makes sense to me now. I did not mention in my original post that I have a 4.2 6-cyl which I think is probably a longer engine. With you having a V8 (and probably shorter), I could see how a 3 row radiator would fit.
Hmmmmm. As of right now, I am sending the 3-row back and getting the 2-row.
Mike
Re: 3-row radiator in a 1985 Jeep CJ7 [Re: onetoncrewcab] #815070 05/29/07 12:46 PM
O
oldgreen Offline
I put a V8 in my cj7 and due to the fact that te jeep is pretty much custom modified by myself space is a consideration. Anyway I took my torch and trimmed the top inside of the grill just up to where the mounting bolts for the hood latch are. Plus a corresponding amount at the bottom. This allowed the 3 core rad to be mounted on the outside of the usual mounting spot of the grill.Basically moving the rad a bit forward giving a bit more room for the fan. In my case it still wasnt quite enough so I did also get the twin electric fans.
84 CJ7 304 HEI 35 BFG,s rear dana 60 with detroit locker,Viar compressor, fibreglass body, 2 1/2 spring lift, TF999auto, Warn 8000 winch, Plus a cool little trailer on 35,s. JEEP stands for just empty every pocket
Re: 3-row radiator in a 1985 Jeep CJ7 [Re: oldgreen] #815071 05/30/07 12:39 AM
O
Oldgreen,
LOL. I was actually looking at what to cut to make it fit too! I decided against that option though. My Jeep hasn't been all cut up and it is a rust free frame and body. So, I'd like to do this without cutting.
Thanks
Mike
Re: 3-row radiator in a 1985 Jeep CJ7 [Re: onetoncrewcab] #815072 05/30/07 09:05 AM
80CJ Offline
I have an 80 CJ-5 with 258 and 3 row radiator but it does not have a clutch driven fan. It has a 16 inch 7 blade fan with shroud. There is a 1" thick spacer between the fan and water pump. Clearance between the fan and radiator core is about 1 3/4 inches. The fan and shroud is the original factory HD cooling setup. With the 3 row radiator the temperature very seldom goes past half way on the factory temp gage even on a very hot day lugging down in soft beach sand.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6202 MB (Peak: 0.7148 MB) Data Comp: Off Server Time: 2026-07-17 00:27:35 UTC
