Well got the new LC motor in... #815149 05/29/07 06:30 AM
triblk6spd Offline OP
Swap seemed to go well. When I get the engine bay all looking good I'll post up some pics. (Day or two) The new motor looks great with the red valve cover, new ceramic header, and the chrome K&N.
I was hoping the swap would fix my main problem but it did not. If you all could shed some light It'd be cool. When I start out in 1st gear, or reverse I get this vibration. It's not in all gears just in 1st and rev. About a second or two into the gear the vibration subsides. If I let my foot off the gas it goes away too. I have resorted to having to take off super slow to keep it to a minimum. The motor (new one and old one) revs free with no real vibration to speak of. My center bearing is new and at highway speeds there is no problems. Any clues? Thanks all.
-J
1999 Corvette FRC AFR205/MTI T-1
2005 Big Dog Ridgeback 117ci
1984 Toyota Pickup 22R
Re: Well got the new LC motor in... [Re: triblk6spd] #815150 05/29/07 09:16 AM
Adam F Offline
Motor mounts?
97 4R, stock, daily driver
Re: Well got the new LC motor in... [Re: triblk6spd] #815151 05/29/07 02:25 PM
4Crawler Offline
Might be something with the rear driveshaft. Might try front wheel drive and see if the vibration goes away, if so that is the culprit:
http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml#FixingProblems
If not, it might be in the tranny, t-case, motor/tranny mounts, etc.
Re: Well got the new LC motor in... [Re: triblk6spd] #815152 05/29/07 02:36 PM
yodta Offline
is this all the time, or only first thing in the morning? you're not talking about clutch chatter from dew or condensation, are you?
msg - '87 xtracab
Re: Well got the new LC motor in... [Re: triblk6spd] #815153 05/29/07 02:55 PM
myyota Offline
Have you checked your u joints ?.
Re: Well got the new LC motor in... [Re: triblk6spd] #815154 05/30/07 07:08 AM
motor mounts are good, u joints have no play, it's not clutch chatter. by checking the front drive do you mean disconect the rear shaft and try driving? sounds like a good idea.
Re: Well got the new LC motor in... [Re: triblk6spd] #815155 05/30/07 07:14 AM
kewlynx Offline
Yep, that's what he means. Make sure you mark the flanges, so that when it goes back together, you're not mismatched for the timing.
It's a good way to limp home if you bash your main D/L too.
**ubi apis- ibi salus**
Re: Well got the new LC motor in... [Re: kewlynx] #815156 05/30/07 06:39 PM
Baldy Offline
Did this vibration start after a lift kit? It sounds like the rear driveshaft angle is to steep.
Re: Well got the new LC motor in... [Re: Baldy] #815157 06/04/07 02:07 AM
1
1986xtracab Offline
my 86 does something similer as well, I was thinking it was my flywheel that i didn't get machined when i did the clutch <img src="/forums/images/graemlins/ignore.gif" alt="" />
1986 xtra-cab 22re
stock everything
1991 bed
Re: Well got the new LC motor in... [Re: 1986xtracab] #815158 06/04/07 02:18 AM
kewlynx Offline
That's likely; that's why we tell folks to take their flywheel in while they've got stuff torn down.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6381 MB (Peak: 0.7610 MB) Data Comp: Off Server Time: 2026-11-02 04:02:14 UTC
