Loss of power #815363 05/30/07 05:18 AM
9
98and94Amigo4x4s Offline OP
The '94 has started to lose power, on occaision, usually on an uphill grade with a full tank of gas. The check engine light comes on, you flutter the accellerator and it goes out and the power comes back. The MAP sensor tests good, as does the fuel pump. If either the Mass Air flow sensor of the MAP sensor is bypassed it runs like something my horses can outwalk. The only code it has registered is "fuel lean". Any ideas? Thanks.
Re: Loss of power [Re: 98and94Amigo4x4s] #815364 05/30/07 11:52 AM
Bansil Offline
Air leak in the plastic/rubber intake hose?Look/feel under the plastic tube,over the ehxaust manifold,holes can and have been melted here before,juts check all connections too.
Goodluck
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Loss of power [Re: Bansil] #815365 05/30/07 08:47 PM
9
Can check that too! Thanks!
Re: Loss of power [Re: 98and94Amigo4x4s] #815366 06/06/07 12:33 AM
9
The computer tested bad. Waiting for the replacement to arrive. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Loss of power [Re: 98and94Amigo4x4s] #815367 06/06/07 05:39 PM
Bansil Offline
who tested your computer?and how.
Thanks
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6045 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-06-21 12:23:07 UTC
