Cleaning up the Runner Hard top
#815419
05/30/07 02:04 PM
How have you guys restored the 4runner hard tops? The inside is in great shape, but the exterior black has faded. Is there a product the brings the the black back, or is it something you can paint? Any input would be great.
86' 4Runner, Manual 22RE, Grey SR5 05' 4Runner 4WD Sport, Silver
Re: Cleaning up the Runner Hard top
[Re: Martini]
#815420
05/30/07 02:59 PM
I stripped mine down 100% . Windows, liner - everything then sand blasted with 90 grit at real low pressure (don't want to gouge the glass)- this cleaned it up real nice . Didn't try to strip it , only clean the surface as it has a texture that would take forever to hand sand. Plus the grit gets into all the nooks and crannies easy. Gave it a wash with soap and water then painted the interior a light gray ( two part enamel) and the exterior I painted white with acrylic urethane. Sand blasted and powder coated the front window exterior trim and had them powder coated. Everything turned out great , looks better than new
85' 4x4 e-cab flatbed 22r carb ((SOLD)) 86' 4runner, 22re , "60 buck truck" 95' 4runner, 22re,5sd, last of the good ones 02' Tacoma prerunner, 2.7L, 5spd., 4x4
[Re: Martini]
#815421
05/30/07 03:01 PM
You could also try one of the fiberglass cleaners.
[Re: Martini]
#815422
05/30/07 03:20 PM
Actually , if you want to be real simple about it , I would use the old paint shop trick of scrubbing with comet , wash it off and paint it.
