Re: CHARGING ISSUES [Re: Silverthorne] #815761 06/01/07 09:08 AM
Davepet Offline
First off, if you haven't, charge your battery. All electrical testing should be done with a fully charged battery. Discharged batteries can cause all sorts of inaccurate test results.
Well I checked the volts at the stud on the alt and Im getting 14.4 which seems about right at idle
Check it at BOTH the alternator stud AND the battery. Keep your negative probe at the same ground point for both checks. A few tenths of a volt difference isn't anything to worry about, but much more than that & you've probably got a bad connection to find somewhere. Don't forget to check the grounds as well as the positive side.
Dave
Re: CHARGING ISSUES [Re: Davepet] #815762 06/01/07 09:30 PM
StillH2O_82 Offline
Checked mine this morning at idle at it was 14.2 at the posts so I guess that is about right.
If your alternator is not an OEM Toyota Alternator just be prepared to get proficient at switching out your alternator. I would have to replace my non OEM unit every 2 or 3 years.
Re: CHARGING ISSUES [Re: StillH2O_82] #815763 06/05/07 01:34 AM
Silverthorne Offline OP
Yea, Ive gotten pretty good at switching them hahaha. Ive got a small problem with them being submerged for extended time periods <img src="/forums/images/graemlins/confused.gif" alt="" /> Thanks for checking on the volts. Just wanted to make sure I wasnt crazy.
I did charge the battery before I tested anything. Even got a new battery and tested that at the store before I left and did it myself at the house. Thats why I was so confused. A few days later and everything still works now. Wierd
Re: CHARGING ISSUES [Re: Silverthorne] #815764 06/05/07 06:43 AM
Davepet Offline
Well, just for laughs, check the voltage (engine running) at both the alt stud & the battery using the same ground point for both checks, like I mentioned earlier, & see how much voltage drop you are getting.
Dave
Re: CHARGING ISSUES [Re: Davepet] #815765 06/06/07 12:46 PM
14.4 @ the battery, 14.6 @ the alt stud. Same as before
Re: CHARGING ISSUES [Re: Silverthorne] #815766 06/07/07 02:00 AM
Davepet Offline
Thats an acceptable voltage drop, is that wire still getting hot or was it just due to charging a low battery?
Re: CHARGING ISSUES [Re: Davepet] #815767 06/08/07 01:48 PM
Not quite as hot as it was getting when I had the smaller battery in there (Which tested as ok and is only 1.5 yrs old) but it still gets warm. I think im going to replace everything with 4 ga just to make me feel better. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: CHARGING ISSUES [Re: Silverthorne] #815768 06/08/07 10:26 PM
ldivinag Offline
possible bad cell in a new batt?
not impossible...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: CHARGING ISSUES [Re: ldivinag] #815769 06/08/07 11:38 PM
A
andykrow Offline
seems like the dumbest thing but this happened to me and it was caused by corrosion in between the post and the clamp. had to take off the clamp to see it. did you clean that off real well? can definitely be an intermittent problem - might explain why it starting working one day...
Re: CHARGING ISSUES [Re: andykrow] #815770 06/12/07 01:57 AM
I think that may have had a lot to do with it. I replaced the entire ground wire but the positive did have some corrosion on it where the wire to the alt is connected. Not much at all but some. Had to change it from the stock config because the wire to the fuse box had broke off. There was a small amount on the connector that I put on. I think it was a combo of a number of corroded connections that has been causing this. Following the wire all the way to the alt I found small ammounts of corrosion at each connection. Each of which normally wouldnt cause much concern but the combo of all of them is what I think caused it. Probably also where the resistance was coming from as well. Thanks for the input everybody.
**** TIP*** Change out that undersized alt wire if you guys are running high amp alts, high power lights,or a winch or anything that, drains that battery more than stock, causing alot of charging by the alt. I swear it even runs better now <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6360 MB (Peak: 0.7592 MB) Data Comp: Off Server Time: 2026-06-23 22:45:39 UTC
