whats stronger? #815942 06/01/07 02:17 AM
smokn03 Offline OP
put a new hg on.and now i think i have a bad head bolt.so what threads are stronger the block or the bolt?torqed good when it was cold but i checked when it was warm and it just turned.and also is my hg still good do you guys think or should i push it off a cliff.or maybe it would make a good fire for a party?
Re: whats stronger? [Re: smokn03] #815943 06/01/07 10:23 AM
dcg9381 Offline
The bad news is that the threads in the block will typically fail before the head bolt threads will.
Typical reasons for this problem:
1) Using late model head bolts in an early block (not enough thread depth)
2) Overtorquing the bolt(s)
Good news is that you can helicoil your block.
One makeshift solution is to use an ARP head bolt in that hole, as the ARP will sink to the bottom of the thread depth. Make sure you clean out the hole before installing the bolt, consider chasing it with a good tap and using a micro vac to get all the crap out.
22REturbo.net
1988 4Runner
Re: whats stronger? [Re: dcg9381] #815944 06/01/07 02:31 PM
bkg Offline
Yank the head, run a tap through all of the holes, Time-cert if necessary, install ARP head studs and never look back.
Brian K. Gallus
Re: whats stronger? [Re: bkg] #815945 06/02/07 09:06 PM
smokn03 Offline OP
so does anyone have a headstud i can buy or do i have to buy a complete set?and thanks for the help.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6001 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-11-03 13:37:26 UTC
