Page 1 of 3 1 2 3
wanna see some flex #816151 06/01/07 10:11 PM
kiarazy Offline OP
02 sportage softtop 1 inch body 4 inch suspension custom exhaust custom bumpers front and rear 31" tires
Re: wanna see some flex [Re: kiarazy] #816152 06/01/07 10:16 PM
Hydra747 Offline
Cool and thanks for the really awesome PICS!!!!
Where did you get that bumper from?
And how is the weather up there in Minnesota/Michigan or where ever your from?
What kind of custom exhaust do you have or make?
Thanks, --- Mike <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: wanna see some flex [Re: Hydra747] #816153 06/01/07 10:20 PM
kiarazy Offline OP
the bumper is homemade and the weather is ok 70 degrees and partly cloudy its going to start raining in about an hour
Re: wanna see some flex [Re: kiarazy] #816154 06/01/07 11:45 PM
DEFBOY35 Offline
thats some good flex. dp you mind giving me the part numbers off of the shocks that you got for the rear. I am going to do the same set up, just need to get some dimensions and which shocks to get.
did you have to do any sort of a coil retainer?
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: wanna see some flex [Re: kiarazy] #816155 06/01/07 11:54 PM
DEFBOY35 Offline
not to steel your thunder, but i figured this would be a good place to post some pics i just took a couple weeks ago of some flex!!!
Re: wanna see some flex [Re: Hydra747] #816156 06/02/07 11:10 AM
A
Adskia Offline
hey mate nice flex..........what did u do with your handbrake cables....in regards to moving brackets down and what not...... <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
THE POWER TO SUPRISE.
Re: wanna see some flex [Re: Adskia] #816157 06/02/07 03:05 PM
Hydra747 Offline
Actually DEfboy----your Body lift looks like it was done properly!!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Mine got cheated at about 1/8 of an inch.
Some dy I'll fix this though....
Nice pictures too! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: wanna see some flex [Re: DEFBOY35] #816158 06/02/07 03:19 PM
kiarazy Offline OP
i will find the part number i know i have it and yes you have to run retainers because there is nothing holding the springs in and for the parking brake you have to take off every clamp holding the cable
Re: wanna see some flex [Re: DEFBOY35] #816159 06/02/07 08:53 PM
DennisThompson Offline
Nice flex on both of them. DEFBOY35 tell me about your hood. You have probably have before but I may have missed it. I was wanting a scupe like on the diesel Kia's but yours is cool also.
Dennis
Re: wanna see some flex [Re: DennisThompson] #816160 06/03/07 12:38 AM
DEFBOY35 Offline
I custom built the hood. it is all metal. there was alot of welding and grinding that went into it. it does a fairly good job of letting the hot air escape also.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6408 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-06-07 03:20:14 UTC
