Any way I can get more travel out of my suspension?
#816424
06/03/07 07:11 AM
I went out to the dunes yesterday.My truck does really nicely But when I get up some speed it really gets to riding rough.So what could be done to soak up some of those bumps?I removed my sway bar.Thats is all I have done though.Stock suspension.
91 Mitsu Montero RS LWB PENDING 88 Cherokee Lifted and modded heavily. FOR SALE 91 vanagon syncro 1.9 TD SOLD 04 Suzuki Aerio Commuter SOLD 90 mits mighty max,v6 SOLD 94 Mits Diamante LS. Stock. TOTALED 71 VW Baja Bug SOLD
Re: Any way I can get more travel out of my suspension?
[Re: allsierra123]
#816425
06/03/07 05:41 PM
Custom pre-runner Ford IFS based suspension!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: rxinhed]
#816426
06/03/07 06:18 PM
Im not going to keep the truck long enough to make it worth investing that much in it.I just want my wife to be able to run it in the desert or on the dunes while Im driving the baja.It just rides way to rough.Would some heavier shocks help?
[Re: allsierra123]
#816427
06/03/07 07:23 PM
Nothing much you can do without spening big bucks but try premium shocks. Let more air out of the tires. Maybe invest in some onboard air if you dont have it already.
Yu can trim the bumbstops in the front but gain will be mininmal.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#816428
06/03/07 07:35 PM
thats what I was afraid of.Seems with the current setup were limited to about 45mph.I dont want to really go much fast just smoother.
[Re: allsierra123]
#816429
06/03/07 09:20 PM
On my 87 Montero I run about 8.5" travel in the front. I had a bit over 9" but was binding the outer CVs so I reduced the travel. Now this is about 4" more than stock and I found a big difference when driving. To get this travel is more work than just cutting the stops, not to mention I still have all the stops in there and if you are running fast you should keep them. What I did was increase the droop travel by reworking the upper control arm by lowering the outer joint and then insuring the shock does not top out. Also watch for CV bind when turning tight, I had also backed off the turning stops to tighten my turn radius. Then I reworked the lower arm to allow more compression travel, I did not run out of CV range but was limited by tire contact to the inner fender.
I am doing this with my 95SR now and am looking to see how much travel I can get there.
[Re: OldColt]
#816430
06/03/07 11:45 PM
When you say "rework", what does that mean? Modify, replace bushings, ??? <img src="/forums/images/graemlins/confused.gif" alt="" /> Weld, cut, bend???
[Re: hazy_daze]
#816431
06/04/07 12:03 AM
Yeah what do you mean?Any ideas on what needs to be done?how to do it?
[Re: hazy_daze]
#816432
06/04/07 01:43 AM
When you say "rework", what does that mean? Cut and Weld, The upper ball joint gets lowered down in the arm to allow more droop. After I had done mine John baker brought some tubular arms to market to do the same thing. I have no idea if any are around. In the lower are I submerged the shock mount to the lower surface allowing more up travel. I then modified the upstop to suit.
[Re: allsierra123]
#816433
06/04/07 07:24 AM
FIVE inch body lift? <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
I must see pics of this.
