Lift and Tire size. #816705 06/05/07 01:28 AM
L
LDeuce Offline OP
Hi I'm still pretty new to the lift thing. My friends and I go mudding all the time and I would like to put bigger tires on my truck. It is a 1987 4x4 SR5 5speed. I was planning on buying some $220/set of rockcrawler wagon wheel rims and throwing some 31 x 10.5 on them. Will they fit with stock suspension or do I need a body/suspension lift??
Also what size could I go up to with what lifts?
The biggest tire I will want to run is 33's.
Thank you.
LDeuce.
Re: Lift and Tire size. [Re: LDeuce] #816706 06/05/07 02:25 AM
4Crawler Offline
See:
- http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10
As long as you keep the wheels close to stock width/backspacing, 31x10.50 should fit fine. Go too wide or too little backspacing (less than 4.75") and you may need some lift to clear, at least up front.
Re: Lift and Tire size. [Re: 4Crawler] #816707 06/05/07 03:51 AM
L
LDeuce Offline OP
Thank you for the info. In other forums I would have gotten flamed. I like this place it's a little more mature.
Re: Lift and Tire size. [Re: LDeuce] #816708 06/06/07 04:32 AM
Snowtoy Offline
I was able to clear 33x12.50 15's w/3.75 BS on this '86 with only a 2" BL.
The tires rubbed only on full lock and not at all after beating down the inner fender seam.
You should be able to clear 32's with some inner fender modification w/o a body lift. Also the type of tire can also effect clearance, not all tires are the same size, some run smaller than others sized the same.
Re: Lift and Tire size. [Re: LDeuce] #816709 06/06/07 10:56 AM
4xJedi Offline
Spend $166.00 shipped om Cragar Soft 8's from Summit. Can't beat the price. They're 4" back spaced so as long as you can afford anther 1/4" inboard you're all set.
'86 4Runner 5" SAS
'97 4Runner
'05 Corolla
'00 F250 PowerStroke
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6054 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-06-19 23:18:07 UTC
