two piece driveshaft #816744 06/05/07 05:33 AM
kc85 Offline OP
i have an 85 ext cab with two piece driveshaft with no cv joint just three ujoints.does the first shaft come straight out of transfercase to csb then down to rear end or are both shafts suppost to be straight.i know angles are wrong just don't know what way to go
Re: two piece driveshaft [Re: kc85] #816745 06/05/07 03:10 PM
4Crawler Offline
Normally the upper half should be straight, since it only has one u-joint. Then the bottom half should have the angle in it and both u-joints at the same angle:
- http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5891 MB (Peak: 0.6369 MB) Data Comp: Off Server Time: 2026-06-21 12:23:47 UTC
