adding lift to my grand cherokee #816864 06/06/07 12:52 AM
0
00grandRodriguez Offline OP
i have a 2000 jeep grand cherokee with the 2" budget lift i want to add the 3" coil springs... do i need to get the sway bar and track bar for the 5.5 lift
Re: adding lift to my grand cherokee [Re: 00grandRodriguez] #816865 06/06/07 05:03 AM
fred1980 Offline
You need an adjustable front trackbar because at 5 inches of lift your front axle will be shifted more toward the drivers side about 3 inches or so. You don't need a swaybar but you either need longer swaybar links OR swaybar disconnects if you want get more articulation offroad. You could probably get away with the stock control arms but I wouldn't recommend it as your Jeep will be stuck with bad pinion angles on the axles which will probably cause vibrations. You will also need longer shocks at 5 inches and could probably squeeze by with the stock brake lines IF you don't offroad your Jeep, if you do then you will need longer brake lines. Hope this helps.
Fred R.
97 ZJ, 5" Long Arm Lift, Beadlocked 35's, 231/D300 Doubler, Locked Front & Rear (Narrowed HP D44 & F8.8), ARB Bull Bar & 9K winch, 1-Ton Hydro-assist steering, "Custom" body work and some other goodies... PICS
Re: adding lift to my grand cherokee [Re: 00grandRodriguez] #816866 06/06/07 05:47 PM
0
Thanks that really helps alot i just didnt know exactly what all i needed to get but that helps thanks again
Re: adding lift to my grand cherokee [Re: 00grandRodriguez] #816867 06/06/07 09:10 PM
0
what do you think about all the other components...should i get the 3" coil springs and that adjustable track bar and get by with that because i dont take my jeep offroad much
2000 grand cherokee wj 3" iron rock, possibly adding 2" spacers...32" ssr...2 12" 1000w competition pioneer subs...2000w nitro amp
Re: adding lift to my grand cherokee [Re: 00grandRodriguez] #816868 06/07/07 03:48 AM
fred1980 Offline
I highly recommend you lift the Jeep right the first time (getting adjustable control arms, longer shocks & brake lines along with the adjusable trackbar) but you can do it with that setup you just described but it WILL affect your ride quality a-lot. At 5 inches you will need longer shocks but you could probably get away with some of these in the mean time...SHOCK EXTENTIONS
Hope this helps.
Fred R.
Re: adding lift to my grand cherokee [Re: fred1980] #816869 06/07/07 06:30 AM
0
does anyone else have ne suggestions
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6120 MB (Peak: 0.6823 MB) Data Comp: Off Server Time: 2026-06-07 04:26:37 UTC
