Montero Limited 2002 Transfer Case problem. #816911 06/06/07 06:29 AM
A
ABTO Offline OP
Hi people.
Mitsubishi Montero 2002 90k miles.
After last off road my transfer case in not working. Front and rear wheel lights on a dashboard go out and central differential lock light is blinking. The situation. I am tried to switch from 4LLc to 4HLc on neutral position but lights continued blinking I am driven some time keep wheel in straight position push and release accelerator but it doesn't help. I stopped and turn engine off. Few minutes latter a start engine and light showing that transfer case switch to 4HLc position but when I tried to switch to 4H central differential start blinking and after some time front and rear wheel lights go out.
Is any body know what possible problem could be? My expectation that safety system device is activated but I have no idea what it does means. Any guess really appreciate.
Thank you.
Re: Montero Limited 2002 Transfer Case problem. [Re: ABTO] #816912 06/06/07 03:10 PM
Alex Kogan Offline
There are several sensors located on t-case which monitor current state total of five if I'm not mistaken: is 2WD engaged, is 4WD engaged, is 4LLc engaged, is center diff locked, is 4H engaged. Most likely one of those gone bad. Prob one responsible for 4LLc but can't be sure. So ECU just leaves it in one position. I've heard of those sensors suffering from corrosion in heavily salted roads environment, in Russia for example. Of course it could be faulty actuator but sensor is more likely. Blinking center diff light is equivalent of check engine like but for t-case. You can read fault codes using MTU scanner used for other engine/transmission codes.
Where are you located?
08 PowerWagon (stock!)
Re: Montero Limited 2002 Transfer Case problem. [Re: Alex Kogan] #816913 06/06/07 06:29 PM
A
ABTO Offline OP
Hi Alex,
Thanks for your answer. I am locating in northern California.
In my understanding Mitsubishi Montero Limited have some difference with Montero XLS. The difference is Active safety device which is located before t-case to prevent t-case damage. I read a doc, when central differential lock is flashing that means safety device is activated. I am tring to understand how it is could be fix.
Please advise.
Thanks.
Re: Montero Limited 2002 Transfer Case problem. [Re: ABTO] #816914 06/06/07 06:51 PM
icysyrup Offline
More than likely I am gonna say that its one of the 5 switches on the top of the transfer case that has gone bad, or the transfer case actuator itself. There is a little black case a little bit bigger than 4"x4" I am guessing. And it moves the shift fork around in the transfer case. I would lay underneath and have someone move the 4wd shift lever back and forth through the range to hear if that is moving or not.(Make sure its in park though...lol) And if thats working then my guess is one of the sensors on the top of the transfer case that will need to be replaced.
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: Montero Limited 2002 Transfer Case problem. [Re: ABTO] #816915 06/06/07 07:50 PM
Alex Kogan Offline
It won't move since ECU might be detecting one of the sensors is band and won't engage actuator.
ABTO, 2002 Ltd is very different from XLS. Ltd uses electronically shifted t-case while XLS uses plain mechanical lever to shift t-case modes. You've got lever too but it only sends signals to ECU. Flashing CD lock lamp means there is something wrong. You need to read error codes and see what is it. Take it to dealer or you if you technically inclined you can try to do it yourself by reading code off CD lock lamp. Ground #1 terminal off the OBD-II connector, turn ignition on count flashes.
Re: Montero Limited 2002 Transfer Case problem. [Re: Alex Kogan] #816916 06/06/07 09:40 PM
4xmonty Offline
ABTO
you must be Olegs friend,I just wanted to welcome you to the board there are many here that will try to help.
Russ <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
Re: Montero Limited 2002 Transfer Case problem. [Re: 4xmonty] #816917 06/06/07 10:07 PM
Alex Kogan Offline
ABTO
Oh. then I guess he might find quite a bit of help here http://www.pajero4x4.ru/bbs/phpBB2/index.php as well. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Montero Limited 2002 Transfer Case problem. [Re: ABTO] #816918 06/06/07 11:15 PM
Welcome! Glad you found the forums. I'm sure the technical know how here will help you resolve your tech issue!
Ray
Re: Montero Limited 2002 Transfer Case problem. [Re: off-roader] #816919 06/07/07 03:59 AM
Alex Kogan Offline
That's your rig. Isn't it? <img src="/forums/images/graemlins/kewl.gif" alt="" /> PM me if you need some bits of shop manual to diagnose your problem.
Re: Montero Limited 2002 Transfer Case problem. [Re: Alex Kogan] #816920 06/07/07 07:04 AM
A
ABTO Offline OP
Alex,
I took on board diagnostic tool II in AutoZone and check codes. OBD said: "No codes returned". I guess that it is special code just for Mitsubishi. Thank you everybody probably I need to check car in authorized Mitsubishi dealer.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6440 MB (Peak: 0.7665 MB) Data Comp: Off Server Time: 2026-06-22 06:05:01 UTC
