Re: Montero Limited 2002 Transfer Case problem. [Re: ABTO] #816921 06/07/07 02:50 PM
Alex Kogan Offline
Before you shell out $$$ to dealer you might what to try this. AutoZone code readers are worthless for diagnosing Mitsubishi.
08 PowerWagon (stock!)
Re: Montero Limited 2002 Transfer Case problem. [Re: Alex Kogan] #816922 06/08/07 12:33 AM
A
ABTO Offline OP
Thank Alex to keep me optimistic.
I found a mitsibishi tester.
http://www.mitsubishitechinfo.com/epacarb/MI05-808.pdf
I found some recomendation to re-programming mitsu 2002 up to 2003-5
Also I call to mitsibishi and service advisor replay that could a two problem. One problem is transfer the case in $800 of cost and some electronic device in $200 of cost and plus labour. Just one little thing to trust what is realy need to do. I'll try to find MUT ||| and scan.
Re: Montero Limited 2002 Transfer Case problem. [Re: ABTO] #816923 06/08/07 05:29 AM
Alex Kogan Offline
Did you try to read CD lock lamp? Any luck? I would try to do that before shelling out $5k for MUT III <img src="/forums/images/graemlins/zombie.gif" alt="" /> I'm pretty sure that service person has no clue about what's wrong. I think it's most likely one the sensors.
Re: Montero Limited 2002 Transfer Case problem. [Re: Alex Kogan] #816924 06/08/07 08:19 AM
A
ABTO Offline OP
ODB Tool does not read transmission codes. No body know what does MUT tool means in Autzone store. Modifications is require in conservatory.
Re: Montero Limited 2002 Transfer Case problem. [Re: ABTO] #816925 06/08/07 04:00 PM
Alex Kogan Offline
Sent you PM. Check your Prive Messages in My Home. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Montero Limited 2002 Transfer Case problem. [Re: Alex Kogan] #816926 06/23/07 06:55 AM
A
ABTO Offline OP
Hi everybody!
Sorry for the late post.
I am kind of happy now.
The problem was with two solenoids how to explain me Mitsubishi repair store manager by the phone. His recommended to replace full complect. I did it. The full cost of it $500 include part and labor, But I paid just $100, because I have the extended warranty. Sorry, I forgot it. This part of the story not is most interesting. The most interesting part it is my conversation with Mitsubishi manager.
Manager: We read two codes from the transmission. Two solenoids is broken. I recommend you to replace all of them.
Me: Are you sure that we need to replace all of them.
Manager: Yes, it is easy to replace all of them. It is better for you and for us.
Me: Ok.
Manager: You will save just $50 if you replace just two solenoids and you will use you car as you use before.
Me: What so you mean?
Manager: The people usually do not use this car off road.
Me: Really, is it off road car?
Manager: Yes, but people don't use it us you do.
Me: ok, you sale people ask me that is off road car, but you don't recommend it to use off road. Mitsubishi charge me for the car and for the service as for the off road car but you don't recommend it.
Manager: ...
me: ok, please replace all solenoids.
Hung up.
After that manager didn't call me back. but did the good service. Why is not excellent? After the repair my engine got low performance. So... I need to find the shop to tune up the engine.
fyi. I have an driving experience since 1965 or so, under further control.. I start driven the car when I was 5 years old it was a huge trucks. I have a bachelor degree in automobile industry.
But, Mitsubishi manager don't recommend me to use off road car on un-pavement road.
Hey, Michael Moore !
Please burn the next move against automobile industry !!!!
I know the name of the move! It is Sicko II.
Re: Montero Limited 2002 Transfer Case problem. [Re: ABTO] #816927 06/23/07 01:44 PM
G
generation_one Offline
...is off road car, but you don't recommend it to use off road. Mitsubishi charge me for the car... But, Mitsubishi manager don't recommend me to use off road car on un-pavement road.
that's funny stuff...well, not that funny. I mean it is interesting.
good to read a follow up on the fix.
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6256 MB (Peak: 0.7341 MB) Data Comp: Off Server Time: 2026-06-23 01:15:51 UTC
