Re: 22RE Surging Idle.... [Re: 4Crawler] #816941 06/07/07 04:29 AM
kmat123 Offline OP
Thanks for all your help guys. I'm taking in into a local shop tomorrow AM to get the cooling system pressure tested. I'll let you know the results!
Re: 22RE Surging Idle.... [Re: kmat123] #816942 06/08/07 11:21 PM
kmat123 Offline OP
Well I took my truck into a shop to get my cooling system pressure tested. They found a small leak in both the radiator and water pump...so yesterday/today put in a new radiator and water pump. While my truck is running better and not loosing coolant the surging idle persists, which leads me to believe that it isn't due to the cooling system. I'm going to clean out my throttle body later this evening to see if that helps, but does anyone have any other suggestions?
Re: 22RE Surging Idle.... [Re: kmat123] #816943 06/08/07 11:28 PM
A
andykrow Offline
Maybe a vac leak in the power brake booster? Pull the hose off the intake, plug the fitting and see what happens.
Re: 22RE Surging Idle.... [Re: kmat123] #816944 06/09/07 01:54 AM
canuck Offline
OK boys, do this and do that, what about a simple comp test that will take 5 minutes......
Keep the Shiney Side up. Support our troops.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6054 MB (Peak: 0.6771 MB) Data Comp: Off Server Time: 2026-11-19 23:53:49 UTC
