Re: 22RE Surging Idle....
[Re: 4Crawler]
#816941
06/07/07 04:29 AM
Thanks for all your help guys. I'm taking in into a local shop tomorrow AM to get the cooling system pressure tested. I'll let you know the results!
[Re: kmat123]
#816942
06/08/07 11:21 PM
Well I took my truck into a shop to get my cooling system pressure tested. They found a small leak in both the radiator and water pump...so yesterday/today put in a new radiator and water pump. While my truck is running better and not loosing coolant the surging idle persists, which leads me to believe that it isn't due to the cooling system. I'm going to clean out my throttle body later this evening to see if that helps, but does anyone have any other suggestions?
[Re: kmat123]
#816943
06/08/07 11:28 PM
Maybe a vac leak in the power brake booster? Pull the hose off the intake, plug the fitting and see what happens.
[Re: kmat123]
#816944
06/09/07 01:54 AM
OK boys, do this and do that, what about a simple comp test that will take 5 minutes......
Keep the Shiney Side up. Support our troops.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6068 MB (Peak: 0.6785 MB) Data Comp: Off Server Time: 2026-07-17 02:20:35 UTCValid HTML 5 and Valid CSS
