CASTOR ANGLES????? 1983 SFA #817183 06/07/07 05:22 AM
4
4x4_YOTA Offline OP
I'm confuz'd(see), FSM says castor angle is 3 degrees, 30' +_ 45'. What does 30 - 45 mean??? I took my truck to Goodyear for an alignment. My castor specs came back as lt frt: 4.94 degrees and rt frt: 5.25. Goodyear says, "specified range" for my truck is 4.25 - 5.75. So, which one is correct, FSM or Goodyear??? Thanks everyone!!! Aloha. <img src="/forums/images/graemlins/confused.gif" alt="" /> Have a <img src="/forums/images/graemlins/cheers.gif" alt="" /> on me....
if u ain't 4 wheelin, whats the sense...
Re: CASTOR ANGLES????? 1983 SFA [Re: 4x4_YOTA] #817184 06/07/07 06:03 AM
4Crawler Offline
My '85 FSM shows 2 +/- 1 degree:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#Steering
30' and 45' mean 30 and 45 minutes;
- 60 minutes in a degree
- 30' = 0.50 degrees
- 45' = 0.75 degrees
If the truck drive's OK, the caster is fine, I think folks run up to 6 degrees with taller tires. Generally you want the caster angle more for taller tires for a little better stability. Too little and you can get death wobble, too much and other things can happen.
Re: CASTOR ANGLES????? 1983 SFA [Re: 4Crawler] #817185 06/07/07 06:30 AM
4
4x4_YOTA Offline OP
thanks, steering is a little heavy while turning and it does not return to straight on its own. An article I read said the cause is too much castor. Thanks again.
Re: CASTOR ANGLES????? 1983 SFA [Re: 4x4_YOTA] #817186 06/07/07 06:35 AM
CORunner93 Offline
" 3 degrees, 30' +/- 45' " mean 3 degree, 30 minutes plus or minus 45 minutes.
The ' (one tick) stands for minutes and " (2 ticks) stands for seconds.
fractions or decimals of a Degree can also be shown as minutes and seconds.....or can be shown as a straight decimal. When the decimal is shown as minutes and seconds, the base 60 minute, 60 second convention is used (60 seconds = 1.00 minutes; 60 minutes = 1.00 degree).
For example:
3 degree, 30 minutes = 3.5 degrees
2 degrees, 45 minutes = 2.75 degrees
4 degrees, 15 minutes = 4.25 degrees
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: CASTOR ANGLES????? 1983 SFA [Re: CORunner93] #817187 06/08/07 01:01 AM
OOP'S Offline
Thanks for clarifying that. I always wondered what the heck that meant.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6063 MB (Peak: 0.6717 MB) Data Comp: Off Server Time: 2026-06-07 07:22:22 UTC
