New Montero Owner here, got her Yesterday !!! #817251 06/07/07 04:45 PM
KarlC Offline OP
Well I pick up a 1990 LS from the orginal owner with 109K miles, Leather, Moonroof and a bad motor yesterday. Its White body is near perfect, the darker brown Leather has no cracks or tears, just worn on the left side drivers seat. Towed(what a pain)her right to the rebuilders for a new motor. I have a few questions......
- Anything special I should be concerned with on the rebuild?
- The front bumper is dented up and a bit bent, is there a replacement option?
- The tail and turn signals are cracked, where can I find replacements.
-Anything else I should be concerned with ????
Thanks I'll keep you all updated.
San Diego CA
Re: New Montero Owner here, got her Yesterday !!! [Re: KarlC] #817252 06/07/07 05:51 PM
Tag Offline
is it a chrome bumper or black?
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: New Montero Owner here, got her Yesterday !!! [Re: KarlC] #817253 06/07/07 05:59 PM
sparkem Offline
Yeah, dont get a Jasper rebuilt engine put in. Get a good quality shop to rebuild it.
Re: New Montero Owner here, got her Yesterday !!! [Re: sparkem] #817254 06/07/07 06:59 PM
KarlC Offline OP
- The bumper is chrome
- Yes I am having a local shop do the rebuild, they have a 3 year 36K warrant. I hope all goes well.
San Diego CA
Re: New Montero Owner here, got her Yesterday !!! [Re: KarlC] #817255 06/07/07 07:26 PM
Welcome. <img src="/forums/images/graemlins/cheers.gif" alt="" /> When you get it back post up some pics.
Re: New Montero Owner here, got her Yesterday !!! [Re: KarlC] #817256 06/07/07 07:32 PM
In addition to the engine...
-Examine the radiator and if needed have it rodded or even re-cored. If it's re-cored consider a 3 row instead of 2 row setup.
-Change all the drivetrain fluids (differentials, transmission, transfer case)
-Relube all the lube points. There are over a dozen zirk fittings to hit.
Re: New Montero Owner here, got her Yesterday !!! [Re: off-roader] #817257 06/08/07 04:54 AM
Your bumper options include stock replacement, Don and ARB units. Don is on this Board.
Re: New Montero Owner here, got her Yesterday !!! [Re: KarlC] #817258 06/08/07 02:28 PM
L
Lee N Offline
The most critical item to check when rebuilding the 3.0 is the clamping range on the head bolts. If the heads or block have been milled for flatness, the head bolts may bottom out (giving a false torque reading) before reaching their proper clamping force. Some here have bottom tapped the block, checked clamping ranges, and even slightly ground off head bolts to make sure the head gaskets are properly clamped.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: New Montero Owner here, got her Yesterday !!! [Re: Lee N] #817259 06/09/07 02:56 PM
KarlC Offline OP
Lee why not just shave a bit off the head bolts ?
San Diego CA
Re: New Montero Owner here, got her Yesterday !!! [Re: KarlC] #817260 06/09/07 05:37 PM
L
Lee N Offline
Probably can. The process I listed was what Frank did. The most important thing is to be aware that several memebers have had head gasket failures with rebuilt motors. Through Frank's effort, this community has pretty much determined that lack of head bolt clamping force was the problem. Make sure your rebuilder checks to make sure the head bolts will clamp before bottoming out.
Lee
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6384 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-11-04 20:50:11 UTC
