Wiring harness question (extra plug?) #817412 06/08/07 05:11 AM
OFFRD88 Offline OP
Hi guys, new to the forum. I've been building my truck on and (mostly) off for the last 2 1/2 years, I really intend to finish it now.
Question is, I have a 2 wire plug (contacts perpendicular to eachother) that I just found unused. I have completed all my vacuum and device install, and it matches the FSM exactly for my year (88 22re EFI). I found a vacuum valve in a box that fits it perfectly, but I have a bunch of spare parts from a 87 22R, so I don't know which it came from. Were there any plugs not used on some harnesses for certain years? The truck is not ready to fire up yet, so I can't give any feedback on how it runs.
I can post a pic or 2 if need be.
Here's my build so far:
88 standard cab truck
fiberglass fenders and bedsides
total chaos front end with heim joint steering and 2.0 7100's (hydraulic bumps to be installed)
all pro offroad buggy springs with flush mount front hangers in rear, SAW 2.5 reservoir shocks
full cage, twin stick xfer case, 4.88 gears, detroit locker rear, lockrite front, 22RTE block with 22RE head, mild cam, CT26 from MR2, 370? cc injectors, GTR skyline intercooler, griffin aluminum radiator, corbeau buckets with 5 point harnesses, pine tree air freshener.
Dave A.
88 P/U lots of mods
95 4Runner on 33's with a Detroit
Couple of mountain bike's rolling on 26's.
Re: Wiring harness question (extra plug?) [Re: OFFRD88] #817413 06/08/07 05:45 AM
stock87 Offline
Pics would help, but an early guess would be an AC idle up VSV? They had the plug type you are describing.
Location of the plug would help too.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Wiring harness question (extra plug?) [Re: OFFRD88] #817414 06/08/07 08:08 PM
OFFRD88 Offline OP
Here are some pics:
Note that I have relocated the various vacuum devices to make getting the VC on and off easier.
The plug in question-
The vacuum switch that fits it (may or may not be from this motor)-
The engine bay-
Dave A.
88 P/U lots of mods
Re: Wiring harness question (extra plug?) [Re: OFFRD88] #817415 06/08/07 11:30 PM
A
andykrow Offline
got that same extra plug... i was told it is for bumping up idle when the a/c is on.
Re: Wiring harness question (extra plug?) [Re: OFFRD88] #817416 06/09/07 05:28 AM
Davepet Offline
It bolts to one of the bosses on the valve cover near the dipstick in picture #3.
I think one hose goes to the manifold & the other to the idle-up valve, I can get more accurate info tomorrow.
Dave
Re: Wiring harness question (extra plug?) [Re: OFFRD88] #817417 06/10/07 08:34 AM
Davepet Offline
Well,I was wrong about where I thought it hooked up. This should answer your questions about how it hooks up, if not, let me know what you need.
Dave
Re: Wiring harness question (extra plug?) [Re: OFFRD88] #817418 06/11/07 12:56 AM
OFFRD88 Offline OP
Ok, thanks. My truck was not originally equipped with A/C, but I am adding it. I'll look through my manual to figure out the vacuum hose connections.
Has anyone tied into this to up the idle for winching etc-?
Dave A.
88 P/U lots of mods
Re: Wiring harness question (extra plug?) [Re: OFFRD88] #817419 06/11/07 01:01 AM
4Crawler Offline
Yep, works well:
http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/20.html
Re: Wiring harness question (extra plug?) [Re: 4Crawler] #817420 06/11/07 03:14 AM
G
Greg_Canada Offline
Truck sounds awesome, any other pics?
89 4Runner
Re: Wiring harness question (extra plug?) [Re: OFFRD88] #817421 06/11/07 05:22 AM
OFFRD88 Offline OP
I'll have to upload some pics to my site and link them.
I confirmed that the plug is the A/C idle up switch, checked the wiring schematics and the colors match.
What I can't find is any diagram for the vacuum hose routing <img src="/forums/images/graemlins/confused.gif" alt="" />. Anyone have a diagram or an '88 with A/C? I do have a plug in the side of the intake plenum, is there another device which goes there in an A/C equipped vehicle? My wife's '95 is too different to use as an example.
Dave A.
88 P/U lots of mods
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6403 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-11-02 19:39:24 UTC
