Effect of Larger Tires #817537 06/08/07 04:57 PM
Rodayo Offline OP
All -
I'm in the process of adding larger tires (going from stock to either 31" or 32"...haven't decided) now that I've done a mild lift. However, I don't have time to regear before a road trip. What, in general, will be the effects of larger tires to the Rodeo (2004 DI) performance at highway speeds (65+) on relatively flat roads without a regear: less power? engine runs at higher revs? I know that speedo will be off and the gas mileage will decrease but I just wanted to know what to expect.
Thanks!
- Jim
1996 Rodeo - 3.2L, 5sp., ARB Bull Bar, Rancho 9000x, Eclipse sound
2004 Rodeo - 3.5L DI, Auto
Re: Effect of Larger Tires [Re: Rodayo] #817538 06/08/07 05:18 PM
L
Ldub Offline
Engine should run @ lower revs, a larger tire makes fewer revs per mile.
I'm running 33's on mine(stock gearing) & just put on 3000+ miles to Moab & back with no issues other than about 11% speedo error(reads less than reality) & poor mileage.(trip avg. 14-15)
Larry W - 99 VX s/c
3" lift w/trimming & BFH mods, rollin' on 33/12.50x20" Nitto Mud Graps. Indy 4x h-d tie rods, lower links & a bunch of other stuff that put the hurt on the wallet.
Re: Effect of Larger Tires [Re: Ldub] #817539 06/08/07 10:25 PM
94rodeo Offline
go for it. You should be fine with only 31's or 32's. Speedo will be off a little.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: Effect of Larger Tires [Re: Rodayo] #817540 06/09/07 08:25 PM
TrailMystic Offline
Going to 265/75R16 (almost 32") from the stock 145/70R16 (about 29") did not affect acceleration or mpg too much (maybe one mpg, if that). The speedo correction is 7%. It might affect towing a little, but our trucks are geared low enough that this change is easily absorbed.
The above was when I switched to the larger Dueler Revo AT's. Later when I went to Interco TrXus Mud tires, I lost 50 miles per tank of gas. I bought another set of wheels and got Revos again. I switch out to the Interco's for serious off-road trips. So, it's not just size, but type of tread that affects mpg.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: Effect of Larger Tires [Re: TrailMystic] #817541 06/16/07 05:23 AM
A
Airborne6176 Offline
I went from the stock 245/70 R16s to 265/75 R16 Dueler ATs for the first 58,000 in my stock geared & 3" lifted '02 RS. Didn't notice that much of a difference except for a slight drop in fuel mileage and speedo differences. I just went up to some Nitto 285/75 R16 ATs w/ Flowmaster muffler, and my mileage fell even lower PLUS it felt like the torque just disappeared...(too much exhaust flow & even bigger tires don't mix). I got a used PowerVault in great condition and I got some oomph back, but the speedo is still off. I get right at 205 to 210 miles per tank in the city (smaller '02 Rodeo Sport gas tank...grrr!!). More ground clearance with the tires however, plus they look nice...
You can't do wrong w/ 32" (maybe even 33") tires, in my opinion. If you are a heavy duty off-roader, stay between 31" & 32". Hope this helps. Good luck and CHECK YOUR AIR PRESSURE!!
'02 Rodeo Sport, 3.2l V6, 4WD Hardtop, 3" lift, Rancho 9000X's, StinkyFab front & rear tube bumpers, K&N Air Filter, PowerVault muffler, 285/75/16 Nitto ATs w/ steel rims, more soon...
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6069 MB (Peak: 0.6721 MB) Data Comp: Off Server Time: 2026-07-14 21:09:48 UTC
